Just Sharing This My Channel Master 1.8 project.
Manikm909
Small'ish Dish Man
Kent, UK
today - cleaned up all the polar mount components, sanded them down - cleaned, applied rust converter, which is currently drying. (pics to follow) - tomorrow, anti rust primer, and then a couple of layers of the top coat (green).
happy new year - all!
Manikm909
Small'ish Dish Man
Kent, UK
Problem is the total length is ok but the threaded part is too long .
You must buy a much longer bolt so the shaft is equal to the original and cut the overlength
why would it be a problem to have threaded rod as opposed to no thread - its only the elevation angle - once set, its set, surely it doesnt matter if its threaded? does it....
'Ere this what you need..12mm studding and 19mm dia nuts...Unistrut..20211231_192516.jpg
Manikm909
Small'ish Dish Man
Kent, UK
thanks mate - so its fine to use threaded rod, i got the impression from some posts here, that it needed to NOT be threaded in the middle like the original bolt was...smooth until 1 inch from the end.
I have used it before now, never had a problem to be honent..
Manikm909
Small'ish Dish Man
Kent, UK
yeah i cant see it being an issue to be honest. thanks. i'll probably do that
Manikm909
Small'ish Dish Man
Kent, UK
found this - sounds perfect
hxxps://www.ebay.co.uk/itm/M12-PART-THREADED-HEXAGON-HEAD-BOLTS-NUTS-HIGH-TENSILE-GRADE-10-9-BLACK-SCREWS-/183602341401?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0
160 or 170mm length - smooth but includes 36mm thread at the end....wish there was a 12.5mm option.
cokeaddict
Vu+ Ultimo4K, Uno4K SE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE v1 & v2, Solo2, Ultimo, Uno, Duo, Motorised CM 1.2m dish, Hybrid Titanium Smart Lnb with CM feedhorn and a Zone2 minidish with Inverto Unicable II
53°E - 45°W
M12 is 12mm, your bolt is 12.5mm you said which would be 1/2"
Manikm909
Small'ish Dish Man
Kent, UK
correct - however, we dont do 12.5 over here, so what are my options.
Which is why an "Imperial" 1/2" UNC bolt is required!
PS: isn't it ironic that "the land of the free" used - and still does" - "Imperial" measurements!
Manikm909
Small'ish Dish Man
Kent, UK
ive just found @cokeaddict link further up this "thread" lol - thanks
Manikm909
Small'ish Dish Man
Kent, UK
all the hilarious comments put me off course.
nelson_b
Contributor
Some 1/2 in bolts here
Looks like you could maybe use an 8 inch one of them and cut off the surplus thread ..... not cheap though .. and no nut with it .. but there are nuts in the sellers other items
I've not found a socket set that hasn't got a 1/4, 3/8, 1/2, or 3/4 inch ratchet.
Metric tyres ? Pah !
Actuator sizes ?
Manikm909
Small'ish Dish Man
Kent, UK
I have three socket sets . All metric
Manikm909
Small'ish Dish Man
Kent, UK
Rust converter stuff applied after sanding off all the rust \ crud \ and flakey old paint.
The rust goes maroon colour.
... and no nut with it .. but there are nuts in the sellers other items ...
No two ways about it - there really are a lot of nuts on eBay!:-rofl2
hexah
Hadrians Wall
If you haven't put up a big dish before beware it is very heavy but pivots very easily so always be careful where you put your fingers when you put the dish face on and are setting it up.
It is easier to do the initial set up with a locking bar than a jack.
The first time is difficult, it is easier to adjust it once you have centered it and got an east and west satellite. :D
