14w new Russian transponder
SimonE
Gloucestershire, UK
Perhaps I didn't give it long enough before moving to another satellite then. Will try again this evening.
Channel Hopper, I put the new frequencies and symbol rates into the transponder list for 14W. Then I did a scan of the satellite looking for T2MI signals. Finally after a while with the box saying it was processing T2MI I removed power & restarted the box. I went then to the 14W listing and they were there. Good Luck SimonE
rodscha
can these stations be received ona classic FTA receiver? i tried,but nothing locked
SatSearcher
West Yorkshire
Big variation in signal strength for me! 11647V comes in at 13.2dB, 11546 & 11564 just under 6dB and unlockable! A bit odd if they're on the same beam!
SatSearcher
West Yorkshire
105cm in West Yorkshire
rodscha
thankyou... 80cm in south france do not do the job at least now...
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
all 3 blindscan in fine on the Edision OS nino pro.
SatSearcher
West Yorkshire
Can't understand why one is booming in and the others are unlockable. Will try doing a bit of tweaking!
Is there firmware later than 1.14 ?
The S/W and H/W versions I have are:
December 20th 2021 for S/W
February 26th 2021 for H/W
Screen grab attached below.
Looks like the GTMedia v8 UHD is outperforming the Octagon non E2 boxes on these feeds.
These GTMedia v8 UHD boxes are reet tasty little bad boys and great value at just over a bullseye delivered to the UK.
Anyone know how the GTMedia Combo are coping with these channels?
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Not enough to lock here (98cm, south Scotland) , though the wind has probably shifted the dish slightly. I think I need another db or two
.. Tempting lol.
My error, I could have sworn there was V8 written - somewhere - on this GT Combo box.
Channels are in on 11.647GHz but the 80cm dish isn't picking up the data on two transponders (currently showing strength 70%, quality 74%).
I'll have time to stick it on larger dish later.
.. Tempting lol.
The v8 UHD is lacking the better menu interface of the GMedia Combo and the 4:2:2 but it has a lot less bugs in it. The v8 UHD seems quite stable and all functionality works as it should without crashing, for me at least.
In my personal opinion. the GTMedia v8 UHD is way better value than those Octagon non E2 boxes and quite a few t'other boxes for the wad.
For a receiver with 4K, auto Poop and mature firmware at just over a bullseye delivered it is a no brainer, pull the trigger, you know you want to.
Also OK on the GT Media V9 Prime blind scanned in easily. Same GUI as the V8 I think..20220227_131136.jpg
Nice one, yes it looks like the v9 Prime has a similar interface to the v8 UHD.
This is off the GTCombo Blind scan - 2.2PF with small Ku pll Universal inserted into orifice of Cband feed
Satfaca
Melmac (46N, 14.5E)
Melmac
With 2.4m, Chaparral Ku polarotor feedhorn.
