40.5W SES6 & NSS806
amdade
1.5m C Band, 1.2m Channel Master offset KU, Technomate TM-6902
Norfolk, UK
2.4m, plate reversed, LNBF set flush with feed rings, LNB angle so heatsink is facing left direction (horizontal)
VE+ (4177L) 11.5 dB
ESPN (3980L) 9.8 dB
anyone else could do on a 1.8 \ 2m would be useful
I'm slightly out of your size requirement with a 2.2 but you could knock off a few % to put you in the ballpark
** Added EBSPro grab as well
amdade
Norfolk, UK
Just noticed this on eBay not sure if any good or anyone tried one ? do a search for...
"C Band Super Feedhorn Scalar Ring for satellite dish reception in 5G areas"
Ah, the Aussie one - shame the shipping cost and import duties are about three times the amount of the feed, made for PF dishes btw.
Iv'e got the AV-Comm / ADL version hiding somewhere in the 'to do later' stock pile but they are a really heavy cast job - shame the Aussie ones are not more local to us in the UK/Eu or i would have given one a shot
Manikm909
Small'ish Dish Man
Kent, UK
for prime focus i guess not offset ...?
sorry @John has confirmed for PF
Manikm909
Small'ish Dish Man
Kent, UK
VE+ (4177L) 11.5 dB
ESPN (3980L) 9.8 dB
similar to what im getting on my 1.8 - but just over....
i dont get how i had 13db at one point, Rimants arms going back on at lunchtime
Manikm909
Small'ish Dish Man
Kent, UK
VE+ (4177L) 11.5 dB
ESPN (3980L) 9.8 dB
i think you should be getting better results based on @nelson_b results....
amdade
Norfolk, UK
Yes PF, that's what I have.
Performance wise yes maybe should be getting bit better but there are so many variables, difficult to be sure. more tweaking needed perhaps :cool:
ESPN I have seen as high as 11.5 dB, varies a bit during the day / weather conditions etc etc
Looks more like a 3G/4G tower than 5G which tend to be more like this:
It is somwhat odd that around here, many 3/4G masts are being installed, as though the providers are throwing objectors off the scent (at which point the top end will be replaced for the one above)
Annoyingly there is one 5G mast already in place just over a mile away to the SSW, and viewable from the roof.
Not guaranteed, there are two main variables.
1. Location in the UK
2. Make of dish
To the best of my knowledge @nelson_b is using a 2.4m channel master offset focus dish with a secondary focus on it.
@amdade is using a 2.4m Fortec Star prime focus petalised dish (the famous tin dish).
I would expect some variation in signal levels, even though both dish dimensions are listed as 2.4m.
@Manikm909
Why not have a scout around for a 2.4m Fortec Star tin dish, easy to transport and perform reasonably well in C-Band?
There are a few forum topics about how the tin man performs in C-Band. Users got pretty decent results with them considering the tin man has been slated in terms of its Ku performance.
nelson_b
Contributor
Sub reflector removed currently, and standard 2.4 Channel Master arms and l.n.b holder fitted .... C band l.n.b. held in place with cable strap and tape ... for quick l.n.b change over to K/u or K/a .... :-)
amdade
Norfolk, UK
2. Make of dish
@Manikm909
Yes quite correct, Fortec Star petal painted steel. good for the price and has survived a few years now. It took a ride on the hurricane winds this winter, looks still OK, but a good chance I have bent it. replaced a support leg, metal paint in various places.... replaced bolts with SS ones... Works with some of the TP's on 43.1W which I thought was pretty good
I only use it for C-band, usually parked on 40.5W
I also have a 1.2m channel master which I use for Ku band, looking at the build quality difference Im not surprised nelson's getting better performance on his 2.4m CM. I would like one of those :-)
amdade
Norfolk, UK
One other thing... The Fortec Star is carbon steel painted, not aluminium, means it is a heavy item. But for the price not much to loose
It is performing OK if it is locking frequencies from 43.1 West.
In my estimation 43.1W is one of the harder to get C-Band satellites in the UK for a decent number of locked frequencies.
Manikm909
Small'ish Dish Man
Kent, UK
i got playboy at some point, but not much more...
Hmmmm indeed - ive been scratching my head since as something just wasn't right.
This might be relevant for @Manikm909 troublesome time with the ESPN tp - Eventually tracked the problem down to my Norsat PLL lnb. This has been giving good results with linear tp's but for some reason it was giving trouble with ESPN.
Anyway - after a lot of trying / changing different lnb's i ended up with our old friend the 'Astrotel Precision Gold' 15K DRO lnb - this gave me about a 2dB increase reading on the Promax to 12dB max and was a solid lock and viewable without drop out's from about 8dB upwards.
Other lnb's tried: Norsat DRO, better results than the PLL.
Gardiner 17K Mini lnb, works ok but similar to Norsat DRO lnb.
Iv'e got another mini BWEi DRO lnb with inbuilt 5G filter to try but i can't see it beating the 'Gold lnb.
All my swaps etc used the AliExpress External 5G filter before the test lnb.
So, @Manikm909 - might be worth trying a standard DRO lnbf as a test ??.
For scopus Chris: Can you remember when we bought those Astrotel Precision Gold lnb's a while back ? , just found the info/receipt in the box - December 2000 , Gordon Bennett
A very good brand.
Manikm909
Small'ish Dish Man
Kent, UK
An exciting Xmas for you then... :)
Yes, be early millennium, when we moved to our new gaff, when I started tinkering with C Band..
nelson_b
Contributor
What dB are u pulling in on that VE plus channel ?
Hi .... because its too hot here to do anything else today ... i rolled out the 1.8 c.m. and set it up just outside my garage ..... just to have a play at 40.5 W C band .... currently using BSC 421 l.n.b. at center focus ... with home made plate .. its struggling with ESPN transponder today ? signal locked but floating above and below 9.5 db ... VE plus floating between 10.3 and 10.9 ... going to experiment with different l.n.b,s and positioning,s and scalar and plate variations on and off over the next few days .......
