Channel Master Feedhorn
teltras
Channel Master 1.2mts superjack 18´´
Famaval 135PM Aluminium offset superjack 18´´
Famaval 1.0mts with diseqc motor Digipower SG-2100A
Andrew/Channel Master 1.2m with Jaeger SMR1224
Receivers:
Gigablue Quad UHD
Gigablue Trio 4K
KIII pro
Dm800HD
Portugal
Do you guys have some info on this feedhorn, part number 3041107.
The holes on the feed does not fit any of my c120 LNB, do I have to drill it? It´s very big compared to the other CM feedhorn
Terryl
Custom built PC
Thats meant for connecting to a wave guide/filter "T" assembly, and used for both transmit and receive on large Ku band Andrews commercial grade dishes.
I don't think you will get it to directly fit any consumer grade LNB.
teltras
Receivers:
Gigablue Quad UHD
Gigablue Trio 4K
KIII pro
Dm800HD
Portugal
This was installed on a 96cm channel master, I have all the other parts that came with it (rejection filter, LNB, BUC etc) but if I drill the holes to match normal C120lnb does this Cm feedhorn will perform better than the CM feedhorn 3040661?
The R/T feedhorns will have a different bolt hole system to the usual receive only feeds.
It is possible to work the six way bolts into the eight way for the domestic systems.
Sell it and it should pay for the right front end.
teltras
Receivers:
Gigablue Quad UHD
Gigablue Trio 4K
KIII pro
Dm800HD
Portugal
