nox666
- Jul 13, 2008
- Sky Dish, Quad LNB. Freesat Tuner in LG TV.
- West Sussex
Hi all,
I am looking for recommendations on how to add support to my existing quad LNB sky dish so I can view Satellite channels on Astra 19.2 as well. I am looking for a cost effective solution please so changing dish, motorised etc is out of the question.
If possible I am thinking about adding a multi LNB mount , mounting existing Sky LNB (only using 1 cable) and buying another LNB (using one of the other cables going into house). Would this work ? If so could you recommend the parts needed please ?
Inside the house, the TV only has 1 Sat port, guess I need another cheapo receiver for 19.2? Or is there a workaround?
Thanks in advance.
Thanks in advance.
