7E (Eutelsat 7B/7C)
pontiend
Contibruter
south yorkshire
CCTV Africa now showing a test card.Maybe due to come live.
pontiend
Contibruter
south yorkshire
This has just come on.
mikeisyou
Feed Hunter
England
I think the CCTV Africa feed comes on daily between 4.30pm and 7pm GMT same transponder
How long has their been 2 versions of Equatorial Guinea on 7E??
TVGE is on 10722V
TVGE International is on 11221H and carries different programming.
7E has only just come back for me with the autumnal leaf drop.
TVGE is on 10722V
About 3 weeks now 11221H started on 22nd Oct.
tom55
TD110
South
After many transponders shut down i notice something weak at 11595 on V pol.
Could it be ethiopia beam?
Here's what I found at 7.0E, a feed at 11581 V,7200, and not at 11595 V.
Added: There may well be a mux at 11595 V, with a symbol rate of 34000 Ks/s from the African spot(?)
stephan94
Bavaria
7mdish
Milan, Italy
No signal at 11595V for me, 2.4m dish in North Italy.
Just noted a mux of BBC radio feeds at 10720V SR 27500 DVB-S. It was a transponder used by Digiturk prior to its move on Turksat satellite.
stephan94
Bavaria
There is something about 11595 V
IQMonitor found this (with 67% probability).
tom55
TD110
South
When 7200 feed goes off check again, but you can already see in your neumodvb spectrum it is there. Maybe a different spot or something that need large dish on europe spot
I want to think that after the feed disappears(11581 V), I can find 11595 V, but many years of experience at 7.0E to catch the signal on the African beam has given me little or no success with my antenna.
But I think every one of us wants to be wrong regarding failure. May the One Above hear me :)
7mdish
Milan, Italy
Maybe something totally out of my area. As I mentioned earlier, no signal here, neither strong nor weak. Absolutely nothing.
I am not getting anything here (UK location) for 11595V.
Also nothing seen at 11.595 V at around 18.46 UK time but i do have a low signal now at 19.45 UK time but just a bit too low to lock at the moment in fairly heavy rainfall. 2.2 PF side saddle pll lnb not at focus. Location-17K North of Nottingham.
Indeed there is a signal on this transponder-11595 V- but I'm not sure that the parameters found by neumoDVB and IQmonitor are compliant. With such a weak signal it is natural that any application, no matter how good it is, can give errors.
Maybe we are lucky that this cold season this signal will be better highlighted and possibly locked.
If I am to anticipate, I think this mux is a Data transmission and probably with an S2X extension. It remains to be confirmed by someone here or from elsewhere.
EnoSat
enosat.euweb.cz
Slovakia
GA?? - 11595 V - Africa Beam E7C
DW8 - 11595 V - West/East Beam E7C
D8 - 11595 V - Europe A/Europe B Beam E7B
