RAI1 etc TPs missing
hairybadger
Bricoleur
46.1N 6.4E
see sig
I've been watching games that aren't available FTV on the French channels on RAI 1 11776V using a valid Tivusat card. The TP is showing very ropey signal at the moment - in fact a rescan didn't pick it up the TP at all. RAI 5 11013H comes through fine. I guess I'm connected to a multiswitch - 13E is on DiSEqC A, 19.2E on B. The weather is a bit dodgy but I haven't had problems with it before.
Hmmm with blindscan I've got it back on 12614V, but the rain margin is zero (raining at the moment, strength is 51% and it's breaking up occasionally). This TP isn't listed on Lyngsat. RAI News 24 on 11011H (listed as 11013 on Lyngsat) is at 69%.
No, I don't have access to the roof or the multiswitch :N.
Mickha
North West
RAI 1 HD is listed as 11766 V 29900 DVB-S2 8PSK 3/4 but the SD version, is on 10992 V 27500, can you get the SD version?
I use kingofsat, to search for individual channels.
hairybadger
Bricoleur
46.1N 6.4E
see sig
1, 12614V not exist on 13E - Home - FlySat Satellite Chart
2, The LOF of your LNB is not exactly 9750 but 9748
Thanks.
It might not exist on the chart but that's how I'm watching it at the moment. Blindscan found it.
I've fiddled with the LOF but it doesn't change the signal quality very much.
hairybadger
Bricoleur
46.1N 6.4E
see sig
I'm not getting anything on 11776V now, nor 10992V. Odd.
EnoSat
enosat.euweb.cz
Slovakia
changing the LOF does not affect the quality, since the box uses AFC (it is only relevant for transponders with a very low SR)
can you post a picture of the result of blindscan 11700-12700V here?
hairybadger
Bricoleur
46.1N 6.4E
see sig
OK, something weird going on. Little in this scan is in the right place. 19.2E appears to be OK, though - Al Jazeera English is on the "correct" TP.
However: Museum UHD *is* 10725H (near enough what Lyngsat has), plenty of Kabelio on 11096H.
Solo2, OpenVix more-or-less up-to-date.
I have one input connected, 13E and 19.2E are on it. Both set as Universal LNB.
13E - DiSEqC 1.0, port A
19.2E - DiSEqC 1.0, port B
voltage mode - polarization
fast DiSEqC - no
toneburst - no
tone mode - off
increased voltage - no
EnoSat
enosat.euweb.cz
Slovakia
I was thinking about what frequencies blindscan will display (GREEN - MANUAL), not services
OpenViX has an excellent feature, transponder verification without real scan (Signal Finder - YELOW Service list)
EnoSat
enosat.euweb.cz
Slovakia
fast DiSEqC - no
toneburst - no
tone mode - off
this problem - 22 kHz OFF - still scan with LOF 9750 (Laayoune on 10873V not on 11721V)
If you want blinscan to show the correct frequencies, you need to set the extended mode
hairybadger
Bricoleur
46.1N 6.4E
see sig
EnoSat
enosat.euweb.cz
Slovakia
defined is used if the user wants to know the correct frequency
