Turksat 4A Ka Band A now active
Kemanci55
Turksat 42-Astra19-eutelsat 9-Azeespace45e-36eutelsat-bulgariasat0.1e- 16 eutelsat - 80e expreas- Gigablue uhd4k enigma receiver and multifeed system
Turkiye
Now i have 12,8 db on 18709 MBVL TV, the rest are not locking with 90cm.
Ka band lnb nereden alabilirim
I am writing from Turkey where can I buy this ka band lnb? I want to buy please help
SimonE
Gloucestershire, UK
Mine is an XMW R9216AF with a FD9000 feedhorn to fit onto my 1.2m CM dish made in South Korea. Its a linear LNB and I insert a piece of plastic into its mouth to get LHC. Their website shows their current range. They will give you a quote if you contact them. XMW INC
Kemanci55
Turkiye
I think it's a little expensive in China and Korea. Do you have a photo of your lnb? is the feedhorn sold separately for ka band lnb?
The one in this link is about as cheap as you will get that will receive LHC Turksat , [ it will need the plastic in the end of the feed cone] Ka Turksat at 42E for an 'off the shelf' 18.2-19.2GHz and it also comes with the cone feed.
If you do use one of these it is important to know that it runs on a LO setting of 17.25 GHz so a receiver must have this to give you the correct frequency readout of your scanned channels. If ordering one, make double sure with the seller that you are getting one that covers the frequency range18.2 to 19.2GHz .
Kemanci55
Turkiye
I contacted a few people, but it is very expensive There is an economic problem in Turkey, they said $187, I can't pay it
Understood :Y ... "Off The Shelf" commercial Ka Band A lnb's suitable for the Ka Turksat channels are expensive - the other well known commercial companies will have a price tag for the feed cone and the lnb could well be in the £500 plus range, which makes the Aliexpress one worth thinking about. Keep a look out for used Ka Band A lnb's, they do very occasionally turn up.
The other option, but you need to be very capable, is to modify ex-commercial 'DirectTV' lnbf's - use the 'search' on this forum for threads that cover this.
Good luck.
Kemanci55
Turkiye
I don't know where I can find it in used working condition, but aliexpress customs shipping vs. $280 in total
In Turkey, ka band is generally sold on the internet and as a rental. Too expensive. I would appreciate if you support me to test the Türksat satellite, I would like to share my test experiences here. Also, no user in Turkey has worked on this lnb, personally I will be the first
Check out this topic in the link below.
It gives details about the Ka-A LNB that was imported from the USA by some forum members.
Kemanci55
Turkiye
I want to receive the signals of this turksat 42 satellite from Turkey alternatively, is there anyone who can help me to buy this ka band lnb?
Unless you are going to pay the full price for a new Ka-A LNB you will need to buy it second hand from somewhere.
The link I provided you with above referred to the Hughes HN9200 internet broadband Ka-A LNB that forum members imported cheaply from eBay USA.
If you can find any of the old Hughes HN9200 internet broadband setups on eBay, the LNB from those is for Ka-Band A, this will be OK for Turksat
You have been given advice about what you need, it is now up to you to search the internet for an LNB and hope you can find one at the price you want to pay.
What have you got to trade ?
Kemanci55
Turkiye
Ticari olarak değil, kişisel olarak kullanmak istiyorum.I have a Gigablue 4k uhd satellite device and a 120 cm offset sab brand dish antenna.
dreamsat
germany
I found a very weak data channel here. The Türksat 4A is also said to have Band B capacity. Could it be checked please?
best regards
dreamsat
germany
very strong signal on 18709 LHCP. The transponder 18773 L is switched off at the moment.
Kemanci55
Turkiye
I want to be the first user to test Turksat satellite in our country.
I don't think anyone sees Ka band tv signal from Turkey. I want to see the frequencies and share the tests
I want to buy ka band lnb but it is too expensive. If anyone is selling used at a reasonable price, please contact me.
dreamsat
germany
transponders all have reception
dreamsat
germany
18709 L 12500 DVBS2/8PSK 2/3 MC 16 Lumen Christi TV is new
dreamsat
germany
19896 L is today very strong
Only 18709L for me now in East Anglia.
Using the old mesh 70cm dish with a modded Saorsat LNBF, hence the odd LOF. I needed to insert a minus sign before the frequency to give the correct frequency readout of the spectrum (Saorsat LNB's have a reversed L-band output).
Testing with a Raspberry Pi 4B.
dreamsat
germany
my scan
