Gibertini 150-Ibu twin-scalar ring KU Band-test @Beli1910
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
As I promised a while ago, I made a video with the addition of a scalar ring on my gibertin 150-ku band. I am satisfied with the results and mainly I have an improvement of the signal on the Clark path.
Test @Beli1910
Test @Beli1910
It would be interesting to see this across a range of frequencies on weaker/borderline satellites. Strong signals are already strong, so not very interesting to see :)
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
I agree with you. My time is very limited, but when I have the opportunity I will do a couple of frequencies.
AtOM13
near Marseille
Triax 100 cm, lnb Inverto black Ultra
Laminas 150 cm
Marseille
I’ve made some quick tests with this kind of scalar ring ( Laminas 150, LNB black ultra):
Eshail 1 @ 25.5e 76% (70% without)
Eutelsat 8W 70% (69% without)
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
In the main, you have to play with scalar and test it. The results are not everywhere better, but not worse either. I hope to find some free time to delve a little deeper into the testing by satellites and draw a conclusion of improvements, or better results using the same.
