47,7° East Eutelsat Quantum
s-band
Essex
I checked it with the big antenna. The 12523 H and 12702 H clearly come from this position. The 12702 H could be telemetry or the beacon. I don't know what the other signal is. Interestingly, I discovered two new signals on 12215 and 12226 H. But I can't unlock it at the moment.
I think that the X is probably BPSK as the CS display flips phase randomly where it should show just 2 positions. Usually, if you just run it for a short time you'll only see the 2 positions of BPSK. It may be a TT&C beacon but I can't look at the moment.
dreamsat
germany
The first picture is from this morning and by noon the two transponders can be received again like yesterday.
In this recent (2022) pdf, the high flexibility of Quantum is described in more detail.
All sorts of up/downlink combinations are possible, including frequency reuse.
So indeed, the entire 10.7...12.75 GHz band may be used.
10872 V,62000,1/4,S2- Data, new. RollOff of 0.05 also indicates the presence of the S2X extension.
11363 V,4200,3/4,32AOSK-GS, new. Maybe someone will confirm this mux; I am not sure about it.
Searching in the lower band, I discover an active mux with appearances like those that have been active for longer. So a full Ku-band search is recommended.
After doing the first time (#503) tests on 47.7E with neumoDVB with inconclusive results, I returned to muxes with a symbol rate of 133000. This time the spectrum looks a bit better, but without correctly finding and locking the two muxes-11790 H and 12020 V, the two muxes with a symbol rate of 62000.
It is amazing how fast it scans 6903x at 47.7E on Linux, about 7 min; unlike Crazyscan under Windows, it seems to take an "eternity."
Interesting that neumoDVB finds a lot of beacons but without a correct identification of muxes with a high symbol rate (133000).
dreamsat
germany
I can confirm the 10872 H. I can't receive anything on vertical.
adonis1
Also I'm getting 10872 H 61900, for first time
