frankviana
- Jan 10, 2006
- Age
- 43
- Satellites/tv
- Brazil
The Ocean 04 improvements work perfectly with the TNAP-5 image from El bandido
with a universal LNB 10492 is received,
non-locked signals are indicated
SRs below 1000 are now received (I don't yet know where the lower limit is, maybe 500)
really great@ocean04
e2_changes_20231223.diff getestet im OpenATV7.4 with SF8008, Signal just above zero is displayed
No, it is CinoGriPLi modified a bit@stephan94
Is that the default skin from the TNAP image that you are using in the 10492 H screen capture?
Or is it another skin?
Thank you.
Test in EDISION OSmio+ 4K:Anyhow this is better than before. How about the radio IP feeds on 30W?
Does that really work in SF8008 and OpenATV? Have you tested other transponders? In OpenVix SF8008 I'm getting nothinge2_changes_20231223.diff getestet im OpenATV7.4 with SF8008, Signal just above zero is displayed
Your profile suggests you have another receiver.but i need ok file for sf8008
its only a txt
Yes, possible with Edision + avl6261. What are the models using this tuner?10492 is now received with a regular LNB?
i have edision os mio and sf8008Your profile suggests you have another receiver.
You could compile one.
