Advice Needed Setting up 16E Eutelsat with 1 Metre dish in UK
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
@danaddison
And just one more post from me that hopefully helps! BBC feed came up for you to try 12718 V 6000
"Stanley" on the sw site isnt one bloke anyway - its various contributors using various equipment in various locations
Manikm909
Small'ish Dish Man
Kent, UK
i have a 1.2m CM - i will test 16e right now
Manikm909
Small'ish Dish Man
Kent, UK
There's a feed called feed.
12643 V 27500
7.2db.
Can u get that
Failing that
NOT A FEED;
HRT2 HD.
11221 H 30000
10.5db
my dish is not fully aligned since replacing motor, job for weekend - but close enough i think
danaddison
100cm Sat dish on Superior Dark Motor Metal Gear DiSEqC 1.2-1.3 USALS GotoX, connected to ground pole
sorry only just see this didnt get a email to say it was posted this website is really really really really really really really slow at loading, i am locked onto Eutelsat 16E, as u can see i have locked onto HRT2 HD 11221 H 30000, please see pic if u can
mod note: Link to 3rd party photo host deleted. Upload images to the forum.
so i can lock onto this channel on eutelsat 16e so it shows that i am pointing at 16e but cant get any feeds on there for some reason, any ideas? if im not aligned correctly why would i be able to get this channel? see image as proof
Update: Still not able to lock onto or find any feeds on 16E :(
A/S edit - twitter link removed
Manikm909
Small'ish Dish Man
Kent, UK
Please can you guys follow me on (Link to my Twitter) and message me on there as this websites way to slow thanks:
yeah you're way off mate - u have some dish aligning to do.
see mine and mines not even 100% aligned.:
you wont get feeds, until your dish is 100% and even then, it comes down to size of dish.
your mates smaller dish, is better aligned than your bigger one is - get up the ladder and get tweaking.
im about 10 miles from you - and using a 15 year old 1.2m Channel Master
Err no Dan you cant use this forum to ask people to contact you on other platforms. Thats not how forums work. Many forums would have banned you instantly for that. Ive deleted one post & edited the twitter link out of a second
Dunno about the others but Im not on twitter & have no intention in joining that cesspit that Elon has turned it into with his meddling.
danaddison
i wasnt asking u but ok fair, lol but this website is very very very very very very slow at loading for me hence it taking ages to respond to replys on here and no its not my internet thats the issue its this website thats slow!!, ps i was talking to @Manikm909 , the reason i asked him to chat on X is this website has serious issues causing it to crash all the time!!!
My Motor is Moteck H-H 180 Motor, My dish is 1.2m Channel Master, My Location is Norfolk, UK, My Dish is ground mounted to a pole, im able to get feeds on the following sats:
Astra 28.2E
Channels and Feeds
Astra 23.5E
Channels
Eutelsat 7E
No Channels or Feeds
Eutelsat 10E
Eutelsat 16E
Thor 0.8W
if you are willing to help please follow and message me on X thanks
danaddison
Astra 28.2E
Channels and Feeds
Astra 23.5E
Channels
Eutelsat 7E
Eutelsat 10E
Eutelsat 16E
Thor 0.8W
A/S - edited.
Manikm909
Small'ish Dish Man
Kent, UK
Astra 28.2E
Channels and Feeds
Astra 23.5E
Channels
Eutelsat 7E
Eutelsat 10E
Eutelsat 16E
Thor 0.8W
you reported here that on 16E you have no channels or feeds, but you provided a picture of your signal level on HRT2 from 16e (post #46)
can you clarify?
maximise your levels on 1w - then go from there. either your motor elevation is out, or your dish declination - or both.
mapperuo
Fife, Scotland
2x 1.8m Raven
1.5m Gibby
2x 1.2m Gibby
Fife, Scotland
If you haven't any channels on 0.8w I think you need to go back to basics in setting the motorised dish up. That should be the first satellite you find and align with, 12418 V 28000 has Sky News on it which is what I use to get lined up.
Manikm909
Small'ish Dish Man
Kent, UK
yeah and you should be reaching 95-98% on that - unless you switch your User Interface settings to read in decibels. Then it should be about 14-15db on sky news on 1w when peaked.
10E You should be able to get ORTC Comoros. Thats a MASSIVE signal. Like the guys are saying though you need to start from first principles on 1W Follow the various guides in the dish set up section.
And I dont really care who you were asking to chat to you on twitter. If you do that again I will block your account here. Its totally not acceptable to ask people to take the help off the site. If for the simple reason when you get it sorted it might help somone with a similar problem in the future.
danaddison
hi yes i had signal on the channel HRT2 HD, 11221 H 30000, but it was showing only a black screen (as seen in the pic i posted), but when i typed in the frequency and pressed search it found it without issues (black screen im guessing its encrypted??) i also have octagon sf8008 (just incase ur wondering), this is what my motor is set to (see image)
ps its taking ages to respond on here as this website is way to slow for me .....,
HRT channels are part time encrypted. SO are the Slovenian channels
As you seem to be doing a lot of complaining you find this web site too slow you are always free to take your questions elsewhere......
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
I suggest that you start searching for the 16E satellite with the strongest frequency from the Max TV package. For more precise settings, use frequency No. 1 in the picture
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
A declination offset angle of more than 8 degrees? Are you north of Iceland somewhere?
And I wonder why the nuts aren't used, for extra securing.
My internet connection is over an old-fashioned telephone cable. I've no complaints about the internet velocity of this website. It is faster than I can type...! :)
Greetz,
A33
danaddison
Can anyone of u help me set my declination correct on my motor please i think it might be off it can only be set between 0 & 8 as u can see from the previous pic my location is norfolk uk
danaddison
Greetz,
A33
not iceland no, Norfolk, UK, according to a manual for my motor i have to set My Declination Angle: "set it by screw b & The scale on the upper mounting plate", so i have to move plate down abit to 7.5, the only thing is the plate goes from 0-8 aka 0,1,2,3,4,5,6,7,8 so there isnt a 7.5 option on there see pic > c1e5fcd8 d82f 446a a303 dbef14a3a7b2 — Postimages any ideas??
