Advice Needed Update Channel List Via Internet / Network
loadedboyukagain
lots and many
somerset UK
hi everyone.
I'm looking for a solution to a problem.
I have a relative that I often have to go round to and retune their free-to-air UK satellite box, its becoming a pain.
I'm looking for a device that I can remotely update the channel list on from my system or PC.
I'm thinking a VU+ box would do it, but they are pricey for an experiment.
Any suggestions for a solution to be able to do this would be really helpful.
I was thinking to have a matching box at my house, then I could download / update the list from my box to theirs
Hopefully someone has some good ideas, I'm quite up on most things sat related but this something I have never tried to do before.
Mickha
North West
Any Enigma 2 based receiver should do it, but these are a lot more difficult, for the user, to understand, if they're experiencing problems with a FTA satellite receiver, depending if it's a dedicaed Freesat receiver, or just a normal satellite receiver.
Can you please post make/model of current satellite receiver?
Manikm909
Small'ish Dish Man
Kent, UK
get a cheap zgemma h2s (twin sat tuner) - and install the "AutoBouquets E2 28.2E Enigma2 Plugin" - then show your relative how to update - very simple!!
crossepg set to update EPG daily - jobs a goodun.
i have 2, one in kitchen, and one in lounge - great little boxes for freesat (dont bother for anything other than 28.2e)
you can get them for under 50 quid on e8ay
loadedboyukagain
lots and many
somerset UK
I got them a TM 1500 (years ago) still working fine.
Yes I did think about using a sky mini box like the 595 model, but my long term worry is these are no longer made and will at some point be unviable.
loadedboyukagain
lots and many
somerset UK
Yes these are the boxes I was looking at but showing them anything technical is a no, I need to be able to do it for them,
Do you mean this box will update automatically over night?
As Analoguesat says above, the out of the box solution is either a Freesat box, or a used Sky HD box, then no more updating required.
Manikm909
Small'ish Dish Man
Kent, UK
yes, they auto update on a schedule defined by you
Doesnt matter which box you use - eventually the whole satellite service will be closed down and everything delivered via broadband streaming. SKy HD boxes are cheap enough you could buy a couple & if the first one fails just swap it out for the spare & junk the busted one.
(The satellite service probably has less than 10 years left)
If they have a reasonably modern tv you could just set up BBC iplayer / ITVX / My4 / My5. Or if the tv is an LG it will almost certainly have a satellite input on it which you could utilise instead.
