I also thought it was a signal problem when I first tried to scan terrestrially, to no avail, after neumoDVB's update two months ago. Still, I didn't know that the app was updated three weeks ago, probably expressly to fix the terrestrial scan....
Same in updateDVB scans OK so not a signal issue.
What are you using to scan with satesco?I also thought it was a signal problem when I first tried to scan terrestrially, to no avail, after neumoDVB's update two months ago. Still, I didn't know that the app was updated three weeks ago, probably expressly to fix the terrestrial scan.
After updating neumoDVB today, I managed to find the terrestrial services.
So it wasn't a signal problem.
OK, thanks. Must be TBS T/T2 card specific.You're right, @Llew; I should have mentioned the 6504 card I used for terrestrial scanning with neumoDVB.
/home/ryle/blindscan_kernel/media_build/v4l/tbs5931.c:217:90: error: passing argument 3 of '__a' makes integer from pointer without a cast [-Wint-conversion]
217 | adap->fe_adap->fe = dvb_attach(tas2101_attach,&gx1132_cfg, &d->i2c_adap, adapter_nr);
| short int *
EXTRA_CFLAGS += -Wno-int-conversion
to/home/ryle/blindscan_kernel/media_build/v4l/Makefile
Probably the correct fix is to replace adapter_nr by rf_in (which is zero). I would not change the compilation flags as that will be one more source of errors in futureHi
I just upgraded to Fedora 40 (currently with 6.8.7-300.fc40.x86_64 Kernel).
When I tried to build the blindscan kernel drivers, I had an error:
/home/ryle/blindscan_kernel/media_build/v4l/tbs5931.c:217:90: error: passing argument 3 of '__a' makes integer from pointer without a cast [-Wint-conversion] 217 | adap->fe_adap->fe = dvb_attach(tas2101_attach,&gx1132_cfg, &d->i2c_adap, adapter_nr); | ^~~~~~~~~~ | | | short int *
I bypassed it by addingEXTRA_CFLAGS += -Wno-int-conversion
to
Probably not pretty but it works for now.
Which tv channels are encrypted with rosscrypt or Rosscrypt2 and is there a Conditional access cam for it??It could be signal levels, but also some of these services are encrypted in rosscrypt, which appears as pixellated images.
Only with log files I can do anything about the remaining errors.
The muxes are distributed by Gazprom. What would be really interesting would be to access the uplink. That would allow btinging some news from the real world into that country.
No
