neumoDVB
RyLe
France
Wavefrontier T90, 8W to 28.2E
TBS 6909-X, TBS 6904SE, TBS 6983
France
That's what I first thought and I restarted the procedure from scratch but I got the same errors.
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
Same in updateDVB scans OK so not a signal issue.
I also thought it was a signal problem when I first tried to scan terrestrially, to no avail, after neumoDVB's update two months ago. Still, I didn't know that the app was updated three weeks ago, probably expressly to fix the terrestrial scan.
After updating neumoDVB today, I managed to find the terrestrial services. :Y
So it wasn't a signal problem.
deeptho
Europe
I have updated the drivers to support kernel 6.8., No new functionality...
RyLe
France
France
Hi and a big thank you for this driver update :)
What are you using to scan with satesco?
Update didn't fix my DVB-T problem.
I've been trying with the TBS 6522 with no luck. Only works with the Sony USB stick.
I have a TBS 6220 in my other PC, but that only has Windows.
You're right, @Llew; I should have mentioned the 6504 card I used for terrestrial scanning with neumoDVB. :)
OK, thanks. Must be TBS T/T2 card specific.
If I get a chance, I'll try the TBS 6220 in the PC, or better still put a Linux OS in the other one.
The 6504 card is multi-standard(S2/C/T), which @deeptho has supported along with other cards for neumoDVB.
RyLe
France
France
Hi
I just upgraded to Fedora 40 (currently with 6.8.7-300.fc40.x86_64 Kernel).
When I tried to build the blindscan kernel drivers, I had an error:
/home/ryle/blindscan_kernel/media_build/v4l/tbs5931.c:217:90: error: passing argument 3 of '__a' makes integer from pointer without a cast [-Wint-conversion] 217 | adap->fe_adap->fe = dvb_attach(tas2101_attach,&gx1132_cfg, &d->i2c_adap, adapter_nr); | ^~~~~~~~~~ | | | short int *
I bypassed it by adding EXTRA_CFLAGS += -Wno-int-conversion to
/home/ryle/blindscan_kernel/media_build/v4l/Makefile
Probably not pretty but it works for now.
deeptho
Europe
Hi
Probably the correct fix is to replace adapter_nr by rf_in (which is zero). I would not change the compilation flags as that will be one more source of errors in future
bredhitman
viark sat 4k
Germany
It could be signal levels, but also some of these services are encrypted in rosscrypt, which appears as pixellated images.
Only with log files I can do anything about the remaining errors.
The muxes are distributed by Gazprom. What would be really interesting would be to access the uplink. That would allow btinging some news from the real world into that country.
No
Which tv channels are encrypted with rosscrypt or Rosscrypt2 and is there a Conditional access cam for it??
Latest Ubuntu 24.04 LTS.
Kernel 6.8 crashes my system (AMD with Radeon graphics) - messed-up screen with password unrecognised.
Compiles OK with kernel dropped down to 6.5.
Same software requisites as with Ubuntu 23.10, but with clang 18.
I'm waiting to see what @deeptho's answer is about the kernel crash on Ubuntu 24.04 LTS.
I'm still working with version 23.10 and have no problems with neumoDVB, but since my version is transitional, so to speak, I'm thinking of the latest LTS, i.e., 24.04. :)
deeptho
Europe
Llew, no idea.
A friend asked me to test the TBS5580 USB Tuner(S/C/T) with neumoDVB.
Luckily, @deeptho's driver recognized the USB immediately, and the app scanned it without problems.
I thought I'd post the test result for those wanting or have this device.
@Llew,
What is the situation with kernel 6.5 with Ubuntu04 LTS?
Did you manage to work with neumoDVB under 24.04 LTS?
Yes satesco, that spectrum scan in my post above was taken in Ubuntu 24.04 LTS.
I chose kernel 6.5, but I would assume any kernel below 6.8 would suffice (still don't know what the problem is with that kernel in Ubuntu).
Download a kernel package (amd64) from Index of /mainline and dpkg the debs to your PC.
deeptho
Europe
Good to hear that it work. I will add it to the readme. I am currently working on improviing the drivers for stid135, mainly to support tbs6916 which has 16 tuners, but it may also improve scanning on tbs6909x
