astra 1p 19.2e
Can someone receive a better signal from the new satellite, or the shifted frequencies, write how much the signal improvement is. I personally scanned again with a blind scan and I don't see any major changes in the quality of the signal on the 1.8m antenna - Slovenia location. On average, the signal rotates 15 -18.5db according to stb. only one freq is with a signal of around 20db, as much as I quickly checked
Go back to previous posts you will find many
Transferred to 1p just now
11228 v 22000
In the check I made a few minutes ago, transponder 2 11229 V is still on 1L.
No transponder has been moved in the last few days.
11038 V
DVB-S/QPSK
22000 5/6
M+ Series
M+ Cine
-left-
11259 V
DVB-S2/8PSK
22000 2/3
M+ Series
-left-
10906 V
DVB-S2/8PSK
22000 2/3
M+ Estrenos MPEG-4/HD 30009
167 118 Spa AC3
119 qaa AC3
11038 V
DVB-S/QPSK
22000 5/6 M+ Estrenos MPEG-2 30400
160 82
81 qaa M+ Hits MPEG-2 30410
168 112 Spa
113 qaa
80 Spa
11259 V
DVB-S2/8PSK
22000 2/3
M+ Hits MPEG-4/HD 30902
162 88 Spa AC3
89 qaa AC3
Sorry for the off topic.. at 9:00 UTC this morning, transponders 71,85 and 101, from ARD Digital (test cards of the SD versions) were turned off. They all came from Astra 1N.
As Marcus21 says, they are cleaning the old satellites.
Como dice Marcus 21 estan de limpieza en los viejos satélites.
End all channels TP101 12422 H 27500 3/4 DVB-S/QPSK Astra 1M Europeo
End all channels TP 85 12110 H 27500 3/4 DVB-S/QPSK Astra 1M Europeo
End all channels TP 71 11836 H 27500 3/4 DVB-S/QPSK Astra 1N Europeo
End 4 channels TP111 12604 H 22000 3/4 DVB-S/QPSK Astra 1N Europeo
Info Card SID: 28534, 28535, 28536 and 28537.
gracias di pulire tedesco tp
11837h start two channel germany
Check the information I put, then zero channels.
When you saw 2, now there are 6 channels, one pending (Astra Caption).
It looks like they had to leave it running this weekend.
What satellite are they on now?
Verifique la información que puse, entonces cero canales.
Cuando lo viste 2, ahora ya son 6 canales, uno pendiente (Astra Caption).
Se ve que lo tenían que dejar funcionando este fin de semana.
En que satelite están ahora??
At 23:00 UTC, they were all turned back on, still on astra 1N.
They contain the following channels (see images).
