Sinanpeter
- Astra 19.2
- Turkey
Transponders are usually changed on Tuesday, Wednesday and Thursday nights.Any tp transfer tomorrow morning ???
let see first astra 1l and 1kr need move all service or astra 1m not all tp moveDo we know if channels on Astra 1M will also join Astra 1P?
Go back to previous posts you will find manyCan someone receive a better signal from the new satellite, or the shifted frequencies, write how much the signal improvement is. I personally scanned again with a blind scan and I don't see any major changes in the quality of the signal on the 1.8m antenna - Slovenia location. On average, the signal rotates 15 -18.5db according to stb. only one freq is with a signal of around 20db, as much as I quickly checked
maybe it plan to move tonightIn the check I made a few minutes ago, transponder 2 11229 V is still on 1L.
No transponder has been moved in the last few days.
Never ever locked here in Yemen when it was on 1L even with 4m antenna ...In the check I made a few minutes ago, transponder 2 11229 V is still on 1L.
You from yemen ? And speaking English fluently !Never ever locked here in Yemen when it was on 1L even with 4m antenna ...
just now locked with 3m 8 db, similar to 1p tps
Yes, I''m ..You from yemen ? And speaking English fluently !
GreatYes, I''m ..
in pakistan it is reported with 330 cm some tp's received.
gracias di pulire tedesco tpAs Marcus21 says, they are cleaning the old satellites.
Como dice Marcus 21 estan de limpieza en los viejos satélites.
End all channels TP101 12422 H 27500 3/4 DVB-S/QPSK Astra 1M Europeo
End all channels TP 85 12110 H 27500 3/4 DVB-S/QPSK Astra 1M Europeo
End all channels TP 71 11836 H 27500 3/4 DVB-S/QPSK Astra 1N Europeo
End 4 channels TP111 12604 H 22000 3/4 DVB-S/QPSK Astra 1N Europeo
Info Card SID: 28534, 28535, 28536 and 28537.
Check the information I put, then zero channels.11837h start two channel germany
