Fringe_Sat
- 240CM Aluminum Prime Focus fixed Dish 19.2E
Inverto Black Ultra C120 Flange Twin LNB
Inverto Black Ultra 3208 Twin LNB
Octagon SF8008 Twin V1
- Cairo, Egypt
Hi Sat Guys,
I am aiming for at least full SKY DE package, my setup is as follows:
Satellite Dish: 240CM Aluminum Prime focus high Depth Dish (old with most paint worn off, the metal is OK)
LNB: Inverto Twin C120 Flange Ku-band (Classic model not the new one)
DISEQC: Generic 4 sat DISEQC
Cable: Televes CCS RG6 cable
Connectors: Generic F connectors
STB: Octagon SF80008 Twin Tuner old version with Si tuners and no M.2 Slot
Images: OpenATV, OpenPLI and others
Results so far:
440 channels in the summer
600 channels in the winter
idk. how but it happened, maybe the sat signal strength increased some how.
almost half or more of SKY DE is missing
I have got some info that an older inverto pro non flange would provide better reception if customized with a feed horn.
I couldn't find a proper feed horn, it should be a 9 rings flat copper feed horn with custom base mod for the inverto lnb, should be insulated to prevent water and dust from getting inside the lnb sensitive parts
I am also think about adding copper on top the aluminum to improve the signals but i don't know this can be done.
I am limited at this antenna size and used antennas, I cant larger antennas nor brand new ones.
What can I do to get the absolute max performance out of this setup?
Results so far:
