Advice Needed Low Symbol Rate Dutch Radio feeds on 16°E
All three streams still here as before (see my post #103)
12.538,5 H Joe FM Vlaanderen (SID 25599)
12.539 H Q-Music Vlaanderen (SID 21438)
12.539,5 H Q-Music Amsterdam/Nederland (SID 21411)
View attachment 167405 View attachment 167407 View attachment 167406
Hm, just been listening to these stations ... as I hear it, it is like this:
12.538,5 H Q Music Vlaanderen (SID 25599)
12.539 H Joe FM Vlaanderen (SID 21438)
12.539,5 H Joe FM Amsterdam/Nederland (SID 21411)
So, the CH IDs don't match.
At this time all three streams run completely the same program/music.
On 12536 is Joe FM, with a different program, and on the other two frequencies is Q Music broadcasting the same program.
Question for our Dutch/Belgian friends ... do Q-Music & Joe FM complement their programmes?
Do I assume correct that their playlists differ only sometimes?
Seems to be much better and a very good quality of music.
I can lock Q-music, but not the others. Unfortunately, the frequency reported by others is incorrect.
Q-music is in QPSK (not PSK8) and at frequency 12541.5.
I locked this with tbs6916, which can lock low symbol rate mixes if they are sufficiently isolated.
This one is really tricky.
This statement is incorrect. The little offsets between us only come from different LNB LOFs so a couple of hunderds of kHz difference is normal.
My locks screenshots here haven't been made by AI and show three different streams.
I do listen to all three of them on both PC (TBS6983) & E2 receiver.
I can now securely claim that some parts of the day all three radios share common programming while most of the late afternoon & evening they all have their very own.
View attachment 167438View attachment 167436
I find when you are trying to lock these narrow signals the only way you know if the frequency is "correct" is if you have a GPSDO LNBF + Reciever or other calibrated instrument.
Between my Ku LNBs I have a pretty accurate Bullseye one (TCXO PLL) but the others can be upto 2Mhz out depending on temperature. I find the use of a spectrum analyser / SDR allows you to find a nearby know referance and then use this to find the reported centre frequency to use . However if the reciever / card is not locked / calibrated the frequency is different again!! I also find my TBS5927 is better at finding signals if I tune low and it will search and lock better in and upward direction.
I find this part of the challange, after all I am sure it is available on the internet with a lot less effort!
Happy hunting
Happy hunting
Both are on 23E, easily obtainable..
I've just given them another go on my TBS6903X, they all lock for me but I have to be quite exact with the frequencies for them all to work (based on what I find in the blindscan for my LNB in NeumoDVB ). They're quite tightly packed together!
I get them on -
12541.06 - SID 25599 / APID 111 : Joe Belgium (Flanders)
12541.56 - SID 21438 / APID 101 : Qmusic Belgium (Flanders)
12542.06 - SID 21411 - QNL AMS / APID 101 : Qmusic Netherlands
12542.06 also has a service label for JOE AMS, but there's no audio PID for this one - no sound is being carried for it on the mux.
Others finding stations in a different order to what they expect must be because of tuners not necessarily always locking to the expected one of the three when doing a scan.
Hi Victor,
I receive on my TBS 5927 PC receiver this signals (Radio 538 and Joe) on Eutelsat 16° East. Dedicated (as backup) for FM transmitters here in the Netherlands.
Frequency is: DVB-S, 10.955,68 GHz, H , Symbolrate 355, FEC 2/3.
