- 57E to 58W, C-band and Ku, DVB-S2, 4:2:2 and blindscan.
- 38.5ºN, 0.5ºW
For me there was almost zero change in the signal I received from 1N at 2E and 28E. The present test is half that difference from 2F's permanent location so I would expect changes to be small.First of all, when positioned on another position than intended the footprint will be different.
For me if the UK beam is less than 15dB down on the beam we are currently seeing on 12325H it looks like we will be good to continue using the exact same equipment we currently use for 1N reception.
