i got uk beam strong now on 2f
i never see 10964h so stronger
Using a 3.5m dish and the peak is just 2dB above the baseline. Not what I'd call strong.unless the dish is slewed well east and is pointing at Israel!
Where?lots of on and off switching now, I suppose they are reaching another testing phase.
The term analogue carrier is misleading as well as a so called analogue "black" signal ;)That analogue carrier ist back on 12303H
Huevos said:Almost the entire band is active.
why because none of us know ses plan our potential new customers base we dnt know until it live and everything is tranfered across to it
You said well-"almost" but not all the band!What's so strange about these tests is the fact that I have not yet seen to make tests in subband, from 10700-10950 Mhz,so much so Astra 2F is scheduled to replace 1N.And we already know sub-band transmissions are certainly on UK spot.In fact this spot most interesting for fans in Europe. As they say, it is more interesting what you get harder than what is at hand![]()
Well if you look at my screenshot in post #361 you will see it was active last night.You said well-"almost" but not all the band!What's so strange about these tests is the fact that I have not yet seen to make tests in subband, from 10700-10950 Mhz,
