Great Signal but NO Picture not even FTA... HELP !
nicmzammit
Dreambox DM800 HD PVR
130cm dish
Malta
Our dreambox has been working fine but all of a sudden there was no picture on any channel.
We changed satellite, turned it on and off, took the plugs out and back in again. but still no luck, its showing strong signal but no picture at all. not even FTA channels.
PLease help as we don't know what else to do???
You need to work methodically theough the possibilities.
First is the dish & lnb still there - and if so make sure the lnb isnt obstructed - its not impossible for a owl or similar to decide your dish is a handy roosting place, or a local joker to remove the lnb or pull the cables out!
Then ask the missus if shes moved the receiver when shes been dusting - that can dislodge cables if they arent fitted very well.
Then consider receiver failure, or cable damage - anyone been trimming hedges near the cable today?? Or maybe a local youth has pushed a drawing pin through the coax cable, or its frayed through and filled up with rain water....
Juan69
Ariva, Samsung and Comag PVR 2 100CL
3 dishes, 80cm, 100cm, 140cm
Murcia - Costa Blanca.
If the dish has moved, the receiver could have locked on an adjacent satellite and that is the signal your receiver is reading. The dish would have to be retuned.
nicmzammit
130cm dish
Malta
Where we live the houses either side of us have both got satellites, but we have never had this problem before.
It's just strange how one minute it was working fine to the next no picture. and trust this to happen when the footy is on.
nicmzammit
130cm dish
Malta
You need to work methodically theough the possibilities.First is the dish & lnb still there - and if so make sure the lnb isnt obstructed - its not impossible for a owl or similar to decide your dish is a handy roosting place, or a local joker to remove the lnb or pull the cables out!Then ask the missus if shes moved the receiver when shes been dusting - that can dislodge cables if they arent fitted very well.Then consider receiver failure, or cable damage - anyone been trimming hedges near the cable today?? Or maybe a local youth has pushed a drawing pin through the coax cable, or its frayed through and filled up with rain water....
they have been checked but nothing different..
Please confirm you're seeing the signal strength, as reported by the DM, on your TV screen as opposed to via some other metering device.
Just vaguely thinking about the connection between Box and TV, that's all.
nicmzammit
130cm dish
Malta
Yes I am seeing the signal on the tv.. When flicking through the channels I can see the signal strength next to the channel shown on the tv screen.
Ok.
It was just a straw-clutching idea!
thecaretaker
Lat: 50.86021 Long: 0.52973
www.thecaretakers.net
VU+ Ultimo, Duo2
85cm Fracarro Penta dish
Inverto BLACK Ultra QUAD
South East Coast, England
May I ask what you mean when you say "you changed satellite"?
Did you have a new dish? Is it possible you changed the dish or position?
Again, clutching at straws, but if you changed dish position, maybe you are not on the correct satellite. That might show a good signal strength but as your channel details are different, not showing any picture. Just a thought.
BM300
Dreambox 7000, 7020, 800HD
HD-USB
8 Dishes
UAE
<sub>Open your box and check that the Tuner is well seated in the slot.</sub>
<sub>Are you using a diseqc swith or it is a direct single cable to dish connection?</sub>
Big-Apple
2x Dm800
1xDm7000
CEE
or end of world is coming :] i got also error but from accident and no tv till monday or longer but mine situation is unknow without signal checker device i just see motor icon
in your situtation it could be even image damage i scored it twice in 4 year during mine dm usage .
