Italian DVB-T2 Mux as T2-MI Stream on 11513V
remlap
Wales
Feel like we're at the start of something again, just like I did two years ago when I first got the 6925.
it pakege from mediaset like 5w or 13 east ?
BlindFaith
TBS 5925
In the SI you'll find:
OriginalNetworkID: 8572 (0x217C) "Italian Digital Terrestrial Television"
ServiceProviderName: "Europa7"
Following on from my MPEG4 video problems (blank screen) on the 33E mux with the 4T2 Analyser, I installed the CoreAVC codec and changed to that instead of ffmpeg. I now have video working fine on the MPEG4 channels.
GPU hardware acceleration has dropped the CPU load down from 90% plus to ~30%.
Thanks go to Ekkehard at 4T2 for his suggestion.
vladan10
bigger dish that you can think .
pc card
Southern Europe,Crete
Yes, I have all the setting as you do, still no video :-shifty
try with cyberlink or if you have core avc codec
i dont have signal on 5W north beam , look from 39E the turkey T2 , on the first picture with ts reader dont show nothing but with 4t2 cool !!
georgekamal
dear experts, has any commercial receivers to receive T2-MI signal?
regards-george
No, it doesn't resolve ACM/MIS carriers. A reasonably priced alternative would be the Skystar 2 eXpress HD if you have a spare pci(e) slot in your PC.
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
I am getting nowhere, blank screens all the time, can you help ? Tried various combinations of decoders etc but still no video
battenfan
1.2m pf
60N 18E
I'm no expert but many problems seem to go away by uninstalling all codecs and installing cccp.
BlindFaith
TBS 5925
What are you trying to receive?
ELIUM
Astra 19.2E, Hotbird 13.0E
ELIUM HD IRD
Germany
Hi everybody!
Does anyone know whether the T2-MI transponder 11513V, 30000 on 33.0E still alive?
I'm trying to get signal on it but the tuner (based on Si2169 demodulator) cannot lock to transponder.
I've tested 33.0E and tuner locked to some other (normal S/S2) transponders (11429 V, 11595 H, 11607 H and 12722 V) but 11513V is always unsuccessful...
Possibly, you can also advice some other T2-MI transponders which can be received from west Germany.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I don't think there is any 11513 V on 33E. I believe there are some T2-MI on 5W.
ELIUM
ELIUM HD IRD
Germany
Thanks for quick replies!
Can you please tell, which T2-MI transponders are available on 5W?
Adam792
Cheltenham
Just found this thread from a search,
This system sounds quite similar to the older system used by Abertis for the Spanish digital terrestrial feeds on 30W.
One PID carries a whole DVB-T multiplex which just looks like data to a normal receiver (with the added complication that the PIDs carrying the data are hidden services and also encrypted in BISS).
You can only see the channels by decrypting the data in the PID then stripping the TS headers for the DVB-S2 PID to leave you with the full DVB-T-ready TS.
This system is apparently nearing end of life (in the next few years) and could be replaced with T2-MI proper (apparently they tested this in 2013-14) which could make Spanish channels easier to receive maybe!
Sent from my iPhone using Tapatalk
georgekamal
so still there is no plug and play receiver for watching T2MI stream channels?
MCelliotG
Thessaloniki, Greece
Nope, if we manage this in Enigma2 so be it, but we can't promise anything!
