Archived-1
Persona non grata
- Apr 14, 2007
- uk
does everything look in order here please ? apart from no signal lol.
Can't see anything incorrect - does your Rx resolve such low symbol rates?
Channel is definitely there right now.
The problem is the very low symbol rates - it takes time to "build up" the signal due to low SR hence you seeing the slow rise in SNR. Don't think it's anything to do with AGC.
my TM6800 reacts the same.There is a problem with the TM blind scan.The blind scan finds nothing on that satellite,even though it has the TPs in the satellite list.Doing a single transponder scan or normal scan finds them.As Captian jack says. I think that it is down to the scan timing out before a signal can build up.
