Foxsat HDR
bigbossa
Havana, Cuba
skydigi box
west sussex
Hi all
want to upgrade my current system I use to get freesat at the moment an old Skydigibox . I have an oppurtunity to get a Humax Foxsat HDR 320gb . my question is are these any good or would I be better off getting something more upto date.
I know that it is only 1080i is this ok compared to 1080p
By common consent it is the best of the Freesat PVRs that have been produced (cue detractors ...............).
It was replaced by a new-fangled model that has a reputation for being buggy.
I have a 320GB version which has been used for Freesat itself and for multi-sat for four years without a hitch.
And there is some excellent Custom Firmware for it to permit operation via a Web Interface, File Transfer, Encryption Flag stripping to allow HD Recordings to be played on other Media, etc.
1080i is not an issue.
PS: You won't get Freesat in Havana, Cuba (Somewhat bemused by your User Profile!)
excollier
Bikes, Booze, Rock & Blues
TD 64 and Humax Foxsat HDR with Raydon's custom firmware
County Donegal - furthest outpost of the EUSSR
+1 for the Foxsat HDR. The best of the Freesat receivers by far, especially with the above mentioned custom firmware.
bigbossa
Havana, Cuba
skydigi box
west sussex
Ha ha Havana! Yeah that was for a laugh on facebook. Just Sunny west Sussex really. thanks for your replies . will get back to you re the custom firmware. The version that's available is the 320 GB
excollier
I bought the 320GB version, upgraded to a 1TB drive last year and have been using the custom firmware for some time now, can't fault it.
bigbossa
Havana, Cuba
skydigi box
west sussex
OK nabbed the Foxsat for £50 looks in good condition . put my post code in and retuned ... it was bought only a about 10 miles away. Seems OK the SD channels don't seen as sharp as my old sky box but the HD channels seem good.iPlayer is v bad much better on my Sammy TV . any advice guys
bigbossa
Havana, Cuba
skydigi box
west sussex
been adjusting the display on my TV and things are looking better with SD :)now.
In the menu software version is HPRSFCI 1.00.21, loader version U 7.54 , update date 27 JUL 2012
Any suggestions on the updating of firmware
That is the latest OEM Firmware.
If you want to install the Raydon Custom Firmware, there are several Threads in the Humax HD Forum, including one started by my good self only a few days ago containing a Link to the Download.
excollier
You have the latest factory firmware and loader, the only upgrade you can do is to use Raydon's custom firmware v4.1.2
Do you guys find 320GB is sufficient? Are recordings on that box compressed to use less disc space? Or are they exactly as downloaded from the satellite?
No idea about compression, but I've never exceeded 30% capacity.
But that's personal preference, of course: If we're not moved to watch within a week or three something we initially thought worth Recording then it gets binned.
It all comes around again soon enough anyway with "another chance to see ....." or some such guff.
It would be interesting to know. Could we arrange to record something in common and compare size.
I guess so. Personally I've got a 2TB drive and I prune it regularly, but still currently only have 400GB in reserve.
Yes, can do a mutually agreed test sometime >> Not today, though. Maybe over the weekend.
BTW, the "File" is actually three (IIRC) files: The .ts File plus a couple of bits that are supposed to render it HDR specific (Can easily be defeated, even for HD content).
Just tell me something you have a timer set for and I'll do the same.
"Countryfile" tomorrow ...........................
I can use gFTP to tell you the nature and size of all three components.
Ok (Assuming you saw my last and recorded the same):
According to gFTP
Countryfile.ts = 3,958,765,248
Countryfile.nts = 5,968,960
Countryfile.hmt = 5,475
Clearly the latter two are insignificant, so let's call it 3.96 GB
According to the Humax itself, it's 3.7GB (I guess that's really Gi:cool:
If you divide 3,958,765,248 by 1024 three times you get 3.686887443 which rounds up nicely to 3.7! Humax are using the proper definition of GB.
Yep.
And it all explains why WD250 GB Drives aren't!
PS: I've no idea where the "Cool" smiley came from. I typed GiB ................. Still, it looks Cool anyway.
I guess your parallel Recording failed ..................................... :(
Sorry, but for some reason the forum has not been emailing me for a while, so I missed your post.
