Eutelsat 10A - Mozambique package
SatSearcher
West Yorkshire
Was just wondering if anyone in Europe gets this on 10832V, SR 8876 FEC 5/6, DVB-S2 8PSK. Some sites list it as being on the African beam, others say it's on the European beam. I can't get a lockable signal, but do get a signal just below lock level (around 8.2d:cool: on this frequency. Anyone get a lockable signal on this?
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
i have had it locked once or twice but usually its too weak in my location.
pontiend
Contibruter
south yorkshire
Nothing here in south yorkshire.
Alien2 100cm dish.
hairybadger
Bricoleur
46.1N 6.4E
see sig
OK - I'm confused. Considering the channels it's carrying (African programming, including for example TV Mozambique) it should be on the African beam, but then if this is the case then there is no way anyone anywhere north of central Africa with a 1.2m dish (going by the published footprint). If it's on the European beam then nobody in southern Africa (including Mozambique) would be able to get it *and* it would be dead simple to get in all parts of the British Isles. How about the same frequency (er - and symbol rate / FEC etc) existing on the two beams?
BTW (I get nothing at all...)
sonnetpete
wordpress.com
Normandy, France
After checking on Flysat, I've got a lock on the encrypted package, using those transponder details with the 1.2M dish and the F15. It's showing an SNR of 10.9dB. As HB says, it can't possibly be on the Ku band African beam so must be on the European one.
nelson_b
Contributor
hi--
similar to " sonnetpete" here for me using 1.2 channel master into F15 11.1 db
odd thing is i only get 12.1 db using the 1.8 channel master into the same receiver?
and even odder is that the M3 skybox wont see it at all from either dish ???
All very interesting indeed lads :)
SatSearcher
West Yorkshire
Glad everyone else is finding this one as confusing as me! Judging by the reports above, can only think it must be on the European beam, but on very low power compared to most of the other stuff on 10A, although why it's on the Euro beam and not the African one considering the channels it carries is a mystery! My current reception on the 10700V to 10950V band is this:
10742V 2894 3/4 (Feed) 13.0dB
10747V 4000 9/10 (TLN Network) 11.1dB
10832V 8876 5/6 (African Channels?) 8.4dB (no lock)
10840V 3255 1/2 (ORTC) 7.7dB
hairybadger
Bricoleur
46.1N 6.4E
see sig
Maybe it's programming for Portuguese-speaking African expats, but then why the lowish power?. A reception report from Portugal or western Spain would be interesting. Maybe there is an un-published Portugal or Portugal-and-southern-Africa beam (yes, I know - highly unlikely ... :) ).
Is not low power, everything is in the modulation ... seems multistream ....
Laser
Hi nelson_b. Which receiver is the screenshot of you show above?
Be interested to know.
Thank you
Retired Mod
www.timo.me.uk
Thank you
That's from the DrHD F15.
I'm curious if this is like the weird signals coming from 28.2E on 11009V and 11186V. I can lock these on my DrHD F15 with low signal levels (showing no channels) but when I try and tune it in on my Technomate 6900 (non-super) it won't lock at all.
I can't lock that 10832V on my Technomate 6900 and unfortunately I don't have access to my DrHD at the moment.
Laser
Well. On 10East 10832 8876 .. Have got them all at around 85% SQ.
Can't watch them as receiver says they are in Conax encryption.
These must be on the European Beam. Got the lot. Was most surprised!!!
No problems receiving it here on 1.2m Fibo.
pontiend
Contibruter
south yorkshire
I am getting these transponders this morning.
10742v sr 2894 tpa uige 87%
10747v sr 4000 82%
10832v sr 8876 78%
10840v sr 3255 ORTC 52%
TM5402 100 cm dish
Hopefully I am on the right satellite for a change.:)
Laser
10970 Vertical 4167 is another good one SQ here 89%
Kveys
Southern Finland
10832V here in Finland 12.6dB (125 Gibby). Comores channel ORTC only 8.2dB here.
That TPA Uige is feed from 2013 FIRS Men's Roller Hockey World Cup (Luanda/Namibe).
SatSearcher
West Yorkshire
Finally managed to get a lock on this, signal is 9.2dB so it must be on the European beam, not the african one. Still not sure why it's lower powered than the rest though!
pride21
Sandown Isle of Wight
hi all tried these transponders also get 10742V tpa feed at 98%,10747V TLN at 94%,10840V ORTC at 76%,10832V at 85%, and 10970V test card at 88%
pride21
by the way take no notice of azerspace its just that these pics were in that file
