TBS 6925 PCi Card with hardware blind scan in DVB-S2 and DVB-S
Dependent on the program used for recording, just like any DVB card.
Another one with 16APSK modulation:
Eutelsat 16A (16E) - 12610 Vertical 4245 16APSK 5/6 DVB-S2 4:2:2 MPEG-4
Romanian league: Steaua - Baia Mare
Eutelsat 16A (16E) - 12607 Vertical 4250 16APSK 3/4 DVB-S2 MPEG-4
Strongest I've seen this 16APSK feed, normally its just about locking for me.
And first sport 16APSK or 32APSK feed for me ever! :)
My only 32APSK feed was NFL football over at 22W and was also first H.264 4:2:2 broadcast. Not seen since
Another one 16APSK hit, this time non-Romanian! :)
Intelsat 905 (24.5W) - 11193 Vertical 2600 16APSK 4/5 DVB-S2
Seeing signs of 16APSK but no lock for me.
Apart from decoding ACM and MIS streams what is the advantage using this card (USB version) over the Prog 7500 ?
16 and 32APSK modulation, high and very low symbol rates.
So the prof 7500 will run all the same software?
remlap said:
Now the question is how do we view it.
Perhaps with this card.Too expensive for our own pockets :(
Same software ? You mean Ebs pro and Smart DVB ? yes with the crazycat driver no problem
Not sure really as I don't know the software. I mean to grab the spectrum and constellation like lots of people have posted in the 2E test thread... and be able to read the NIT.
The way I see it if this can do everything else the TBS device does, I'm willing to forfeit the ASPK and save 140€.
Can you give the link ?
I tried this wilth Crazyscan and yes you get the constellation stuff and can stream to ts reader etc
