- Dec 10, 2004
- Age
- 59
- Website
- gso-satellites.nl
- Dr.HD F16, TBS 5927, T-55, Laminas 120 cm
- Oss, NL (5.5°E 51.8°N)
There is already a "scale reverse" possibility in Crazyscan:I'd have to beg Crazycat that there should be an addition to the lnb -type- list ..
ie Directv Low band with sup2400 ..
or simply a scale reverse button.
rgds
VS
Selecting LNB "Ka-band" gives LOF 18750 and range 19700...20200 MHz
Selecting LNB "Ka-band Inverto" gives LOF 21200 and same range 19700...20200 MHz
Note the Inverto option uses an LOF above the receiving range.
Long ago in this thread I suggested your case has an effective LOF of 20450 MHz.
So did you try that already after selecting "Ka-band Inverto"?
