Eutelsat W7A 12467 H 27500 AD Sports
mikeisyou
Feed Hunter
England
Hi guys,
I seem to have lost signal on 12467 H 27500 which contains Abu Dhabi Sports channels, can anyone confirm this and if it has moved to a new frequency/transponder thank you
Got a new dect phone by any chance? Thats a bullseye frequency for L-band interference from dects
mikeisyou
Feed Hunter
England
hmm i don't think i do but thanks anyhow
Next door - the other side of a shared wall?
Just an idea - around 12460 comes up regularly as a problem freq and 80% of the time its a new dect phone, BT homehub etc..
Agorima
80 cm dish pointed to Astra 19,2° east - Ferguson FK 8500 HD
San Cipirello, Sicily
Hi guys,
On that frequency, ADM added Abu Dhabi Al-Oula HD and Abu Dhabi Al Emarat HD.
The frequency should be still there.
I can't check it because the dish is not aligned correctly and there is the darkness.
BlindFaith
TBS 5925
8dB SNR with 120cm
mikeisyou
Feed Hunter
England
i feel like a complete prat now, when i posted my fixed dish on nilesat was pretty much working fine apart from ad sports not working but now whenever i plug the coaxial cable in, a strange smell comes from the lnb input off my spiderbox 9000hd which ive had before when i broke my really old sky box (plugged wrong voltage cable in). It seems fine running off my motorized smaller dish, dunno what to do other than to use alternative boxes which don't pickup dvb-s2 frequencies.
Agorima
I have checked the dish.
It's aligned correctly, but I can't tune the frequency because it's now in DVB-S2 :(
The frequency 12226 H 27500 is still in DVB-S, but until when?
buckshee
HD1 to HD6 ok here, no frequency change
Agorima
buckshee
Try 12226 H
27.5
3/4
Nuren
Eutelsat west 7A
Kenya
Hi guys,
Hello, its also the same problem with mine. The FREE channels 1,2 and extra. anyone got information as to why the signal is not there. The Australian Open is starting in January and i don't wanna miss it. help mike
buckshee
Free channels AD sports 1 & 2 are live on:
Try 12226 H
27.5
3/4
Agorima
The situation is now as follows
Abu Dhabi Sports 1 HD 2 HD and Extra HD are on a DVB-S2 frequency, meaning that you must get a receiver which can handle the DVB-S2 transponders
12467 H DVB-S2 8PSK 27500 2/3
Abu Dhabi Sports 1 and 2 are still on a DVB-S frequency
12226 H DVB-S 27500 3/4
mikeisyou
Feed Hunter
England
We never suggested we didn't have a DVB-S2 compatible receiver. I receive Nilesat in the UK meaning I am on the fringes of the satellite footprint but i have been able to pick up Abu Dhabi Sports before on that frequency. The other frequency does not work because it requires a larger dish where I am.
Archived-1
Persona non grata
uk
Hi mike, I am getting ad sports at the tp you posted on my 1.2 dish, ive had the dect phone problem before that A/S mentioned if you have a neighbour with an adjoining wall ask them if they have moved/changed there phone in any way good luck :-).
I've changed the Topic Title as AD Sports HD is on W7A, not Nilesat: The difference is not trivial as W7A is a relatively easy catch, albeit it is actually at 7.3W, as compared to the remaining Nilesat TPs which have always been tricky in the UK. The SD versions of AD Sports are indeed on Nilesat 102.
Is your dish aligned to 7.3W, or is it aligned to 7.0W?
mikeisyou
Feed Hunter
England
Just did a factory reset on the box and its working fine, must of been some weird Spiderbox glitch
