Skybox LAN Tool
I Dump the Image and all Ancillary Files for both my F3s at least Monthly and (because I like Redundancy & Diversity) do it both by USB and by using the dedicated LAN Tool that can be downloaded from the Manufacturer's site.
Now I've binned Windows completely, I have discovered that the LAN Tool will not open in Linux Mint using WINE.
Filezilla (Other FTP packages are available) is known not to work (a. I Googled it and b. I've tried it) as well.
Not too bothered, as I've still got the USB method, but I was a bit surprised the Tool isn't Linux friendly as the F3 Firmware is Linux based (albeit protected from tinkering)!
Has anybody had any success at getting the Skybox LAN Tool to run under Linux? If so, how?
Is WINE the only thing available in Linux? I use VMWare Fusion in Mac which runs everything Windows (including the OS obviously)
AFAIK, CJ.
And WINE happily runs some other quaint hobby bits and bobs with .exe heritage (Bell Ringing Simulator; On-Board Diagnostics for my Car).
But I hope I'm wrong and someone will prompt an alternative!
Bump.
Still no joy.
Tried PlayOnLinux and it crashed!
sonnetpete
wordpress.com
Normandy, France
Strange, Filezilla loads and connects to my VU+ ok (see screenshot). Though I've yet to try and transfer files. Edit : Under Linux Mint
It's an issue with all Skybox/Openbox: Summat to do with using an esoteric Port, apparently, and requires the Custom Tool. Which only works on something called "Windows".
I'll just carry on using USB Dumping instead.
Piltdownpaul
No.1 Spike Milligan Fan
I'd have a tinker myself Tivu, but i installed Linux 16 Petra Cinnamon last night and had real problems with bugs. I'm back on Mint 15 now as xbmc and google earth run so much nicer. I just dont fancy a crash at the moment.
You must be a mind reader: I made a Live USB Stick of Petra yesterday and was going to play with it after my 1st Jan Data Backups.
Maybe I won't!
Piltdownpaul
Even my firefox would freeze after 5 mins each time i rebooted. I messed about until midnight then off it came ,normal service resumed.
Well it's supposed to be the stable release now, but hey-ho.
Cheers for the Heads-Up.
Piltdownpaul
I'm sure the updates will take care of it in time. I'll stick with mi mint for the moment. I'm a bit of an update junkie, the skybox is updated twice weekly on average. usb styley.
Archived-1
Persona non grata
uk
Sorry to hijack this thread and I hope you find a fix for the problem, when the lan tool is working on windows is it possible to mess with the usb stick recordings from the laptop/pc please ?
It's just an FTP tool and from recalling its features before I binned the dreadful Windows O/S (VHS vs. Betamax? The worst one won), it can only "see" the same system files and ancillaries that can be dumped to USB.
ie Not Recordings ................
Piltdownpaul
I havent got my skybox connected to my network at the moment.
Got mine connected via Homeplugs now. Brill.
Archived-1
Persona non grata
uk
Thanks I was just thinking if it was possible to get the 4.2.2. feeds to pc without removing the usb stick saves getting up.
Piltdownpaul
No ethernet plugs spare at the moment and i cant be bothered to use it wirelessly seeing as i dont use any of the "apps" installed.
Piltdownpaul
No plaice for a flatfish,have you no sole or are you flounder ing.!
Nope. It definitely won't do that.
Oddly enough, I hake to tell you this, but I anticipated the Fishy stuff even as I Posted.
But I've haddock enough of this herring-do.
