The TPs that migrated last night from Astra 2A are coming in here in Maspalomas, Gran Canaria at around 80% quality. 2F PE achieves about 60% quality. (Well installed 90cm dish, Inverto Black Ultra single LNB, Technomate 5402 HD M2).
My conclusion is that they are therefore on 2E (and not 2F).
Based upon reports indicating that ITV's 2,3 and 4 have migrated to 2E, I'm assuming that here is the appropriate place for this post.
ITV's 2, 3 and 4 HD.
Input 1 signal strength 100%
Input 1 signal quality 95%
Input 2 signal strength 100%
Input 2 signal quality 95%
These figures are way in excess of what they have been previously, possibly double on the input 2 numbers. Presumably, reception will continue when there is the slightest hint of rain in the air.
The official dish size for the Canaries is 120cm for 2F. I have proven that a properly aligned 90 cm dish with good quality LNB and receiver will pull it in (I have two such intatallations). Unfortunately many people here have old installations with poorly aligned dishes, poor quality LNBs and old, low sensitivity receivers and do not receive 2F. I am expecting to receive some reports from a local forum today which should make it clear if such systems can pull in 2E.If you look at the PE footprints for 2E and 2F, 2E seems more favourable to the south than 2F. This seems to be the case judging by your findings on your small dish.![]()
120cm was good for 2A North in Fuerte and Lanzarote but no good here in Gran Canaria.
Sent from my GT-I9205 using Tapatalk
can we know your setup in tunisia please ..many thanx
In the past, the signal is weak
Now High signal here in North Africa
11798 H & 12344 H
Yes, that'll be due to the 1N PE stuff moving to 2A last night.
Don't yet know whether it'll stay on 2A or move again.
