This morning I woke to a loss of BBC (ex 1N) Verticals but Horizontals (except HD) were OK. Channel 5 from 2F was also OK. Since then I am getting a little pixelation on the BBC horizontals, but have lost Channel 5 completely (which is normal). So an initial impression is that 2E is coming in more consistently than 2F. It is a Channel Master 2.4m offset dish with Inverto Black Ultra LNB and Amstrad DRX-890 receiver.
Later today I am going to setup the Technomate 5402 HD with a TV on the roof and see if I can tweak a bit more signal quality out of the scew and "long neck" adjustment. I think the dish alignment is probably OK (and I wouldn't tackle that anyway).
Many people with 3m prime focus dishes here are reporting total loss of BBC. I think most of them have Invacom LNBs as these were commonly installed back in the 2D days.
That is on 2E PE and is unlikely to be problematic.C5 HD still loud and clear on the EPG. 100% & 95% respectively on both inputs.
I looked into it in the old days, but they are very rare here. The professional installers do not favour them for some reason. I am a very big fan of Inverto Black Ultras. I get 2E PE on a 90cm dish using one and the BBC Satback at 27.5W with a 120 cm dish using one also.Have you tried the CM feedhorn - I hear these are better than a normal LNB on larger CM dishes.
A bottle of vodka is €3.95 in the supermarket!!!2E - looks like a glimmer of hope there for you!
I don't know why you Canarians bother with TV - I'd just sit outside all day with a drink that has a little umbrella in it.
Interesting. I see no difference on BBC1 between V or H. Channel 5 is also currently reading 75% Strength and 50 quality% as normal for this time of day (so it seems). Expect this to rise to 60% quality later in the day.
( sorry no tech stuff) I have lost all BBC channels this morning except BBC news, Parliment, Radio 3 and 4. First thing this morning I was getting BBC north west but breaking up, gone now
Reports I have seen from Tenerife have been +ve. If you can get a recommendation of a good installer they will probably be able to get your channels back for you. Ask on local forums.( sorry no tech stuff) I have lost all BBC channels this morning except BBC news, Parliment, Radio 3 and 4. First thing this morning I was getting BBC north west but breaking up, gone now
Those frequencies don't make sense. Could it be interference?10860v 0.8db
spot beam 2e
10888hh
spot beam 0.8db
Thanks for that I found channel 959 BBC 1 wmids works perfectly and 971 BBC2 wales as well.Hi Lynne welcome to the forum. Are you still getting BBC News & BBC Parliament?
Assuming you have a Sky box have a jump along the BBC channels up near epg 950 - various other regions are available on ther same frequencies as these two.
