uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
Really ?? Using the same scripts ?? That's good news ....
I haven't tested. I was just saying the AAC caching that solved the audio problems for HD channels is now incorporated into OpenViX.
digi247
NW
see sig
41 page thread ouch, could any one point me to what boxes work/which are the best to get these channels?
Easiest ones are probably the Technomate Range TM5402HD and the new TMF3/5 also the Clarke Tech 4100 and possible a few others
kota
VU+ Solo2,Humax HDCI2000,Astra2 1.80m Famaval dish/Inverto Black Pro,Astra1&Hotbird 90cm dual lnb dish,Astra3 1.20m dish,Intelsat 907 80cm dish, Hispasat 60cm dish.
Sintra - Portugal
Got it. Thanks m8 ...
BBC3HD / CBBC HD now reported on 27.5W
Ah. Oh well - cant check this one direct as its behind a tree here :D
Retired Mod
www.timo.me.uk
And of course I can't check as that would be naughty, it's just what I heard down the pub. :D
Deso
1.2m Generic dish, Sky+ HD and Technomate TM5402 HD box.
Fuerteventura/UK
Deso
Fuerteventura/UK
The labels were there but no channels. Maybe Kota can confirm this.
kota
Sintra - Portugal
BBC Three HD and CBBC HD have been there for ages. The labels you're probably referring to are for STV HD and UTV HD which aren't channels at all.
Deso
Fuerteventura/UK
Been there since they launched.
I have just re read this and realised I misunderstood the statement. You are right timo, BBC3HD/CBBCHD have been available on 27.5W since the channel launched in December. :)
nml
Gibertini 1.5 dish, Gibertini 1.2 to motorize, Funke 1 mtr motorized.
VU+ Duo,3 dreamboxes,2 Foxsat hdrs,, 3 digiboxes and relook 400s.. Satcatcher mk4 Nit, Satlink 6908 and an old Lacuna.
Granada, Spain
Can anyone tell me what frequency I should use on my meter to align the dish on 27.5 I have tried some of the preinstalled ones with no joy.
Satcatcher mk4 nit.
nml
Satcatcher mk4 nit.
nml
10959 V 8332 S2 data
11120 V 2750 S2 data
11138 V 4535 S2 data
Deso
Fuerteventura/UK
Satcatcher mk4 nit.
nml
11.495 V 44100 9/10 is what the channels are on. What is this other frequency William?
These are data transponders that you can use to lock onto the satellite IS-907
Deso
Fuerteventura/UK
Ok, does using these make it easier to find rather than using 11.495?
nml
Granada, Spain
Unfortunately the meter wont take the parameters of 11.495, so no dish alignment, hopefully William -1 has provided what I need so will test tomorrow all I have on the meter is a load of rotary frequencies.
nml
