- Oct 21, 2006
- See signature
- North Somerset
Yep, they are huge! Everything is twice the size...
Alright ... it's more or less finished. Tried to fine tune it just now but it's very difficult with the changing clouds and a fickle Astra 4A transponder. Should be sunny later so will try and fine tune it slightly later, though I doubt I will gain much more. I am off about 0.3dB over what I had yesterday in fine weather on the same transponder. Also, when I put the C band LNB on the bracket, the LNB arm leans down very slightly, throwing the alignment off...
The dish seems to be straighter than ever as there are no gaps at all between the strings. Perhaps it straightened itself out even more once it was up?
Very happy with my declination adjustment mechanism. It all feels very solid and the small jack has no problems driving the dish.
Anyway, here are the final pictures.... the only thing that is likely to change is the addition of a linear C band LNB on the other side.
View attachment 63236 View attachment 63234
nice job --
the Gibertini is much more user friendly than the channel master - when it comes to adding the C band l.n.b ,s alongside the K/u
regards ----
