Hi Kota. I've seen many helpful posts from you on a number of forums, may I ask if you are using Vix? I have tried Open PLi and BH but I always return to Vix and based on some of the comments I have read the suggestion is that the services from 907 are only available via Open PLi, though I seem to recall reading that you had managed to get it working on BH/Vix (I can't remember what you might have written). I would like to use Vix so would appreciate a heads up if you have managed to get it to work.
All the latest images based on openPli are OK for this as long as you install dvbsnoop once flashed, VIX included. Never managed to get it to work with Black Hole images so I gave up on them. At the moment I'm using openATV 4.0 which I honestly think is the best image around for the Solo2.
Also, installing oscam-ymod requires different methods for every given image even though they're all based on openPli so it's better to install it manually but you should know where each of its folders goes to.
The easiest way to get this going with minimum fuss is flashing openSpa 3.1 image. It's got everything you need from their own feed, configs included, almost like plug and play. The only snag is that the default language is Spanish but you can change that to English latter on.
Cheers
EDIT: something I said is not correct. I did manage to make it work with BH but never been able to clear the HD channels AAC-HE sound.
