joddle
- 2x Pace 2600 C1 (in a box just in case) , 3 x Humax HD Foxstat (2 of which in store as spares) . 3x Manhatten Plaza - Pasat 2.4 PF dish mounted on flat roof with Invacom C120 quad LNB .
- Massanassa, Valencia, Spain
I'm afraid so. This is the same feedhorn that came with a 2.30m dish I also used to own years ago. I also have one of these IRTE ones lying around which I still have to try on my present 1.80m. I'll report back once the weather improves.
That's interesting - I suppose the focal distance has been made on each dish so the same feed-horn can be used - perhaps preferable to having to specify and make different feed-horns for each size of dish. This being the case then I guess the distance from the centre of the dishes to the feedhorn must be a function of the diameter of the dish! But if that's the case how does the same feedhorn work when petals are added to the 2.3 dish?
EDIT
Ah - Hevos popped in whilst I was writing with most of the answer....
