Archived-1
Persona non grata
- uk
The above is still active and has been all day, it must be a test channel ?.I am getting bein sports here tagged AJA W6 11081 V 8888 I guess its a feed.
I cant get anthing from 10731. Its been months since i had anything from that freq.
hoi,
is now multi stream channel transponder.
you need a computer tv card to see
Thanks 2night, that explains it then, I will have to set my card backup at some point, i am missing out on lots.
You only need something like the TBS6925 to view these Multistream channels but a standard receiver should still pick up the signal, I have a funny feeling that these channels have swapped Footprint
Thanks BlindFaith, I have locked it a few times, but not since it went FTAhere reception is poorSNR=6,7 dB with 120cm and TBS5925
Agree with you, although I do not have any multistream card I cannot even see a signal.
yes indeed.. According to crazyscan the mux is signalled as ACM/MIS (only a one input stream active). If you check the mux with TSReader the mux rate is 28,5Mbps whereas a carrier with 45000MS, 8PSK, 2/3 yields 54Mbps. No problem with TBS5/6925 but how is that possible with a DB8000?Something not right
