Can't believe I'm actually contemplating this ...
VS, have you considered producing an Anthology of all your Projects? Could be a Cult Classic.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I sort of had a running diary of projects on our beloved forum ..but sadly I have no access to these any more ..as I suspect old stuff is now deleted.
So no real references or photos to refer to..
rgds
VS
I'd be surprised if it isn't available somehow - our Admin friends are very clever chaps and I'm sure lots of stuff has been rescued in the past in the wake of the metamorphosis from VBulletin to IP Board to Xenforo.
Some of the pics may be missing but the basic threads should be available somewhere
If you can give me some keywords I'll see what I can find.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
After a re-think I may be ok with the PLL on the side it currently is as I can still access up to 70 East if I don't use a restricted receiver ..
Will try later on the TBS card ,,
atm I'm still investigating 55.5 W with the motor at 63.9 ..
phew ..
Didn't fancy climbing again anyway..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
the Christina resurrection thread was probably one of my best ..
certainly one of the longest..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Just completed Vertical scan of 55.5W ...using the TBS card..
Rede Meio Norte 4111V locks at 6.5db
RTP 4102V locked at 5.9db
Data Transponder 4055V 30000 locked at 3db
Now starting H scan
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Not much to add on H ..
Just a feed 3964V 7504 6.4db..
I'll construct a thinner more RF transparent cap from Polycarbonate to replace the supplied blue plastic cap ..
soon .
This may gain another 0.5 to 1db.
rgds
VS
I'll now see if I can reach 58W ..but it will be borderline,,
What I will say is the C1PLL appears to perform well on small offset dishes
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
As expected 4040H 26590 NRK mux solid at 3.1db ..
On to the Vertical scan..
...which completed with nothing found ..again ..
not unexpected
Ive spent an hour rereading the disaster thread from end to end. What an inspiring thread that was - I had forgotten how we all chipped in with suggestions on that one.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well sadly I cannot lock anything at 86.5 East but then ..I really didn't expect to ..
I can see quite a few peaks in the trace but nothing substantial ..
I can say it was an interesting idea ..but a forlorn hope at best..
The restricted C1 PLL will be fitted with a depolariser plate ..and a more transparent cap ..and will remain permanently on Tom ...wind permitting..
rgds
VS
Anything on 46-57e range on the triax?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hints of signal but basically sod all ..same as Carl ..and Christina .
Azerspace is simply a no go here ..
I'm out of footprint ..
All others are circular so can't test these with no plate installed.
Interestingly tho' ..
Just locked United TV 3746H @37.5 W ..at 6.1db
rgds
Are you going to try it with the plate in?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
yep ..when I'm ready to brave the climb again ,,
Soon I hope ..and as already said ..
This is how it will remain ..and with a more transparent cap of polycarbonate.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I knew it! :D
For orientation, you may try first to catch Intelsat 906, 64.15° East, 4094 L 3680. It's strong even without depolarizer.
Got that Freq on Intelsat 906 (3 channels - Atlantic - News and Sports ) - though not opening - then I got these as well - Fta
