46E (Azerspace 1)
Give us the SIDs pls
Yes they are there...am locking them with 1.5....but with the 1.2 it's on & Off
A new one on 46E I think.I got it with a blind scan on 45.7e last night.
It has now been listed 46East on flysat.
BUTOV AZTV 11055H sr 1000.
11055H 1000. Still coming in strong on 46.0E
A change in the picture.
TM5402HD 100cm Dish.
11055H 1000.
Got a picture .Sortoff.A broken still.:)
TM4502HD 100 cm Dish.
Edit.Sound and vision now.Though it is a still picture.
11055H - I can get a lock on that tp but it takes so long for the signal to lock that it wont actually scan the channel in :(
I got it first with a blind scan on 47.5.On 46.E I only scanned that transponder in advanced search.
I wonder if the reciever lingers longer on the transponders in blind scan and advanced search.
Just an idea. Probably wrong.:)
A blind scan bought Butov in on a SR of 875!
No signal when looking at it, but a tp edit back to 1000 has allowed it to be seen - a static image with green blobs all over it!
I get the same thing.At first I though that it was that 4.2.2 thingy.But for awhile I got sound and vision.Now back to blotchy screen.
Me sayin the same ting.
Just done a check with my 100cm and TD88.Not a lot of difference.perhaps the TM gets this transponder better.
TM5402HD 100cm and TD88 Dish
It comes and goes.Ten minutes since that last post. the signal is the same, but black screen.
I am getting it with solid black blank screen with logo top righthand corner using sr of 1000
Yes, I found that you need quite a bit of signal to lock this. On my 1.2m Fibo, I get about 9.7dB and that's OK. But with the 90cm one, it's more off than on at about 8.5dB.
I must be in a good spot.My old TM1000D+ That lives in the shed has no problem with it.
Black screen though.It would probably not cope with video with that signal level though.
TM1000D+ 100cm Dish.
