TurkSat 4A/3A@ 42 East
Comparison here on the F3:
Turksat 4A
12344 V 30000 72%
12378 V 27500 72%
12422 V 27500 72%
12457 V 30000 72%
For comparison readings with my set up
Turksat 2A
11919 V 24444 73%
11957 V 27500 74%
12130 V 27500 73%
So bugger all difference really. :D
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Assuming the green area on the map provided by William is the C band footprint area ...
this would confirm what I already suspected from previous info..
No C band from 4A here in the UK
Doh!
..Hope I'm wrong...
@AS: I've never seen Q readings over 75 on my F3s, so suspect that's a quirk of the metering, and in reality there may well be differences - they just cannot be discerned without "proper" meters.
Doh!
..Hope I'm wrong...
Green area is not beam C-Band, Ku-band beam is Africa (frequency 12500 ~ 12750 Vertical).
Doh!
..Hope I'm wrong...
No mention of C band given in the link the green map for Africa is for Ku band
http://www.flysat.com/turksat4a-beam.php
12422 H 30000 3/4 QPSK is now locking, slightly above the 4.5 dB threshold (scanned Turksat Tanitim promo).
12245 H 27500 5/6 8PSK is 7.5 dB already, but this mode needs 2 dB more so that will probably never happen...
12379 H 30000 3/4 QPSK is absolutely 0.0 dB, I suspect it's the Turkey beam!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cheers guys ...
looks like there's still hope then..
What you need - what you really, really need - is a 3.0m Dish, VS.
I know where there is one up for grabs too :D
mar-val
Slovakia,Zilina
New tp. 12329H 6666 2/3 8PSK,Fox HD.
A test program -Fox TV? -12337 H,5520,3/4,QPSK,with strong signal,but than desappeared.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Turksat Tanitim. 6.2db. Gibby 1.2 Dish. Rec. F15
bonou2
strong 4500, openbox X801, vantage 7100ts, vantage X201 CI, goldenmedia 9080,goldenmedia uni-box2,tbs6925+,inverto black ultra+C120,panorama er-861, zinwell lnb 15K C- band,intersat 20K
Türksat 4A @42º East-------Footprint
The 4A footprints are almost as bad as the Insat ones. One beam is basically a line drawn round Turkey that covers the conquered bit of Cyprus but not the rest.....
Footprints of Turksat 4A more detailed..
adonis1
12072V 20.0 db !!! extremely powerful ( 20.0 db it's the ceiling of F15 )
12245H 19.0 db , also too strong .
12072V no signal a few minutes ago - its now on with a very unsteady carrier.
Its yoyoing between 25% & 65%!
Switching errors!
10982H 9600 is on the west beam instead of the east beam as is 10966H 15200 DVB-S2
:D :D :D
meridianu
5W-4W-1W-4.5E-7E-9E-13E-16E-19.2E-23.5E-28.2E-31.5E-39E-42E-45E-46E-53.5E
Brasov
Country: Romania, City: Brasov. Dish: 90 cm
