Just Sharing This UK Dish Size Guide 68.5 east to 55.5 west
This Dish size guide is for Ku Band Satellites received in the UK Revised & updated October 16th 2014
Intelsat-20-----------------------68.5 east-----100cm
Intelsat 17-----------------------66E-----------80cm (European beam - mainly data services)
Intelsat-902 ---------------------62 east-------100cm
NSS-12----------------------------57 east-------80cm
Yamal------------------------------54.9E-------80-90cm (European beam)
Yamal------------------------------54.9E-------1.2m (Northern beam in central UK)
Express AM-22 --------------------53 east-------80cm to 120cm
Yahsat------------------------------52.5E---------80cm for the currently inactive European beam. No signal on the other beams.
Intelsat-10-----------------------47.5 east-----100 to 120cm
AzerSat-1 ------------------------46 east-------80cm (West beam)
AzerSat-1 ------------------------46 east ( No reception on East beam with 100cm)
Intelsat-12 ----------------------45 east-------70 cm
Turksat 2A/3A/4A east ------------42 east ------80cm for West Beam reception
Turksat 2A/3A/4A east ------------42 east ------180 to 300cm East Beam
Hellas-Sat-2 ---------------------39east--------60cm to 80cm,
Eutelsat-36B----------------------36east--------100cm reception only for European beam---
Eutelsat 31A----------------------30.8 east ----100cm
Eutelsat 33A ---------------------33.2 east ----100cm
Astra-5B--------------------------31.5 east ----120cm to 240cm
Arabsat 5A -----------------------30.5 east -------reception possible with 150 to 240cm in the UK
Eutelsat 28A----------------------28.5 east-----45cm to 60cm
Astra 2A/2E/2F/-------------------28.2 east-----45cm to 60cm.
Badr- 4 --------------------------26 east-------100cm to 120cm = South UK ----- 120 to 180cm = North UK
Badr-5 & 6------------------------26 east ------No reception with 100cm dish in the UK
Eutelsat 25B / Es'hail-1 ---------25.5 east---- No reception with 100cm dish in the UK
Astra--3B-------------------------23.5 east ----80 to 90cm
Eutelsat-21B----------------------21.5 east ----90 to 120 cm
Astra-1-KR/1L/1M/1N---------------19.2 east-----45cm South UK----60cm North UK.
AMos 5-----------------------------17E---------a few tp on 1.5m in southern UK.
Eutelsat 16A----------------------16 east ------80cm
Eutelsat Hotbird13B/13C/13D--13 east------60cm
Eutelsat-10A ---------------------10 east-------90 to 120cm
Eutelsat -9A ----------------------9 east-------70cm
Eutelsat-7A/7B --------------------7 east-------80cm
SES-5 -----------------------------5 east-------120 to 240cm for this Nordic beam
Astra 4A---------------------------4.8 east-----100 to 120cm Nordic beam
Astra 4A --------------------------4.8 east-----80cm European beam,
Eutelsat 3B -----------------------3.1 east-----100cm
Thor-5 & 6 -------------------------0.8 west----80 cm European beam
Thor-5 & 6 -------------------------0.8 west----100 cm for Nordic beam in South East England
Intelsat-10-02 ---------------------1 west------90cm
Amos-2 & 3--------------------------4 west------100cm to 120cm no reliable service in UK
Eutelsat 5 West A ------------------5 west -----80cm.
Nilesat-102 ------------------------7 west------100 to 150cm for some vertical transponder's for Horizontal Tp's
240cm + but no reliable reception possible in the UK as we are well outside the service area for this
satellite,best reception is on the South coast of the UK,
Nilesat 201 ------------------------7 west ----------------{ No reception in UK with 100cm dish}
Eutelsat 7 West A-------------------7.3 west-----------100cm South East England
Eutelsat 8 West C ------------------7.8 west------------ (No reception in UK with 100cm dish)
Eutelsat 8 West A-------------------8 west-------------100cm.
Express AM44------------------------11 west------------90cm
Eutelsat 12 West A -----------------12.5 west ---------90cm
Telstar-12 -------------------------15 west -----------90cm
Intelsat-901 -----------------------18 west -----------90cm
NSS-7 ------------------------------20 west -----------90cm
SES-4 ------------------------------22 west -----------90cm
Intelsat-905 -----------------------24.5 west----------90cm
Intelsat-907 -----------------------27.5 west ---------90cm
Hispasat-1D/1E ---------------------30 west------------80cm
Intelsat-903 -----------------------34.5 west ---------90cm ----(only occasional feeds here not very active)
Telstar 11N ------------------------37.5 west ---------90cm -----(Occasional feeds)
Intelsat-14-------------------------45.1 west----------90cm
Amazonas-1--------------------------55.5 west----------90cm
If you take this guide to another site please mention where it came from,
Regards William-1
A few extra details added - A/S
adonis1
Eutelsat Hot Bird 13B/13C/13D @ 13° East ???
aceb
Prof Tuner 7301 /
Sussex
Tony Daly
1.2mt motorised dish
South West Ireland
Great stuff William.
How about Yamel 402 @ 54.9' East.
About 80-90cm for the European beam. Ive had a couple of tp on the Northern beam on my 1.1m - one is normally available all the time the rest disappear at the merest hint of cloud
Thanks for the feedback I can only receive satellites from 53 east to 55 west,
Satellites outside these parameters are based on maps & feedback from other satellite enthusiasts with larger dishes than me,
Such as Badr 5 & 6 with a 180cm dish on the Isle of Wight,
Please share your knowledge as Analoguesat has done in the post above all contributions will help others :)
Cant remember if / when you run out of edit time on the first post william, but if you do find you cant make changes let me know & I'll change it for you
I ran out of edit time Analoguesat so please change thanks.
FWIW Im getting Yamal 55E European beam plus one Northern beam frequency (12604) on an offset lnb on my 1.1m which is aimed at 46E
I will have to try & move the 90cm dish up a couple of cm or add an extension to the current pole :D
adonis1
I think you have to add also "Yahsat-1A @ 52.5° East"
80cm here when the European beam was active a couple of years ago. Nothing on the other beams here.
The DVB-S2 Saudi Sports channels were an exceptionally easy catch here :)
Yes I remember the European beam on Yahsat 1A we had National Geographic in Farsi/Persian & English came in @ 85% signal quality from 52.5 east now nothing,
Other disappointing satellites are Telstar 11N @ 37.5 west massive capacity but only occasional feeds from the USA,
SES-6 @ 40.5 west got some 90% signal quality when it was testing on the Atlantic & European beam now only data in DVB-S2 ACM & DVB-S2/32APSK ACM/VCM in the Ku band :eek:
The outer satellites get much less traffic these days since the increase use of the inner satellites 16E,10E,7E,5E,3E,1W,5W,8W,12.5W,15W,24.5 W & 30W,
18W,20W,27.5W,34.5W are almost dormant now:(
Even SES-4 has less activity than NSS-7 had when it was at 22 west ?
Piltdownpaul
No.1 Spike Milligan Fan
Great work William- a useful guide for new hobbyists and seasoned pros like myself!
