65E Amos 4
pride21
Sandown Isle of Wight
hi all I had a go amos 4, flysat list a data channel on 11255H 6984 its coming in at 95% quality but no lock its acm/vcm.
At this time there are only test carriers on this satellite:
pride21
hi satesco this transponder is just past 64.2E would you know where this transponder is coming from if its not amos 4
Hi pride21,
This test carrier is for Amos 4.It's still active now.
Here's how Ku-band beam on this satellite:
pride21
many thanks satesco for your confirmation on that
Kveys
Southern Finland
According to Flysat there´s now channels on 10860V/10915V. These mostly familiar from C-band nepalese/Indian channels using likely India beam. No signal here unfortunately.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Yes I tried them this morning but no luck.
adonis1
Also no signal.
mar-val
Slovakia,Zilina
Can´t believe this...thanks DVBS2/QPSK and low FEC
margusten
Lat 59.40 Lon 24.68
DR.HD F15, TBS-5925, Dream 800PVR, GM TripleX
Aerial AS24 polarmount 95E - 13E Ku+C, fixed 3M 28.2E, 27.5W ...
Estonia
mar-val
Slovakia,Zilina
Hi, it depends on mode and FEC. S2/QPSK 1/2 is locking very low C/N.
What pictures ? You mean pict of some channel? I will make some tomorow,if I get signal...:rolleyes:
margusten
Lat 59.40 Lon 24.68
Estonia
Yes, I mean picture of some channel. Is it watchable or disturbed?
Seems that FEC 1/2 is most important. Half signal and half control bytes.
I have to try these channels too.
bonou2
strong 4500, openbox X801, vantage 7100ts, vantage X201 CI, goldenmedia 9080,goldenmedia uni-box2,tbs6925+,inverto black ultra+C120,panorama er-861, zinwell lnb 15K C- band,intersat 20K
I tried to catch something...unfortunately bad luck
mar-val
Slovakia,Zilina
Well, it's pretty windy here, signal unstable ,but I got some pictures with DR.HD. It is right on the limit.
For a watchable picture is needed more than 1,2 , I think .
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
bonou2
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
So if these two Freqs are on the Russian beam then not much of a chance of receiving them.
tempo
47.5N, 42.2E / Russia
I have very low signal below lock level, so it isn't Russian beam. I had very powerful carriers during tests on the same transponders.
mar-val
Slovakia,Zilina
What size of Dish are you using please.
It is Kathrein 220cm.
I saw some reports: Germany-360cm, Poland 270cm,colleague Onacila from East Slovakia -250cm.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
Wish I had that size, mine is only 150cm.
