- Oct 21, 2006
- See signature
- North Somerset
Thanks, VS! A job for the weekend... If all else fails, will get one off HM Sat.
What's this, Martin - do you have a link?
My original G-Box has been humming since new - I have to hit it(!) to get it to shut up. Still works fine, though.
No doubt it would do the job CH ...but I nearly fell for something similar recently ...till I queried the lack of a remote ..Not sure if I posted these before, but a charity shop had a few of these in their electrical bin a few weeks ago, I bought one for 2 pounds since I was a bit sceptical that it could do the job.
I'll run it up over the weekend.
View attachment 72032 View attachment 72033
A nice device ...though perhaps a bit pricey ..LOL yes I tap mine and it shuts up .here you go Alex,
http://www.titaniumsatellite.com/pr...larity-Controller/p/28731561/category=6743545
A lot of electrical units from the far east use what I call 'biscuit' or wafer remotes ..As you can see, there is no room in the box for packaging, or a remote.
still a bit underated ..as are the Alshat boxes
Yep ..'tis very nice Martin ..Depends where you read the review's i guess, i don't think its a bad price tbh, its a nice looking bit of kit that does the job and you can programme it via computer.
I'm waiting for them to bring out a dual positioner combo to accomodate 2 jacks ...with one control line..
AZ/EL is the goal
Well, you might as well create an LNB skew-er while you're at it!
3 different types of the C model Alex,I thought the 'C' on the end meant it was an Az/El model?
