Astra 2G Launch: December 2014
astra 2g near 19.2e ?
At this time, the 2G beacons are very weak for me -
Consider that telemetry are still circularly polarized and global or omnidirectional coverage.
tempo
47.5N, 42.2E / Russia
Hardware: USB DVB-T dongle provided with RTL2832U chipset (E4000 tuner or R820T).
Your method of direct satellite tracking by telemetry signal is interesting. Can you suggest us some particular models of DVB-T dongle please? Which one do you use?
I have the 2G 11710.5 beacon (if that is indeed 2G) now moving east towards 21.6E .
04/01/15 10:05.
I am using the Terratec Cinergy T Stick+ (chipset RTL2832U/E4000), no longer in business.
This is only part of the declared compatible:
NooElec TV28T v1 (chipset RTL2832U/E4000)
NooElec TV28T v2 (chipset RTL2832U/R820T)
NooElec NESDR Nano (chipset RTL2832U/R820T)
NooElec NESDR Nano-P (chipset RTL2832U/R820T)
NooElec NESDR Mini (chipset RTL2832U/R820T)
NooElec NESDR Mini+ 0.5PPM TCXO (chipset RTL2832U/R820T)
NooElec NESDR Mini 2 (chipset RTL2832U/R820T2)
NooElec NESDR XTR (chipset RTL2832U/E4000)
EzTV666 (chipset RTL2832U/E4000)
Newsky TV28T v2 (chipset RTL2832U/R820T)
ezcap USB 2.0 DVB-T/DAB/FM dongle (chipset RTL2832U/E4000)
Terratec Cinergy T Stick RC (Rev.3) (chipset RTL2832U/E4000)
Terratec NOXON DAB/DAB+ USB dongle (rev 2) (chipset RTL2832U/E4000)
Compro Videomate U620F (chipset RTL2832U/E4000)
Compro Videomate U650F (chipset RTL2832U/E4000)
KEEDOX DVB-T USB TV RTL-SDR FM+DAB (chipset RTL2832U/R820T)
Notes:
Tuner E4000, frequency available 52 to 1100 end 1250 to 2200 Mhz.
Tuner R820T, frequency available 24 to 1750 Mhz.
04/01/15 10:05.
By my calculations, is about 20°E (just be glimpsed telemetry of Eutelsat 21B )
Better to follow the 2G KA beacon, clearer spectrum field.
~18800V @ 20E. 1L KA Newsnet mux still visible.
Other screenshot @ 19E, ~18794V 1L KA beacon.
Astra 2G TLE #10 of 4 Jan 01:53 UTC: 19.8°E at that time. No inclination any more.
Moving 1° per day, estimated now at 21.7°E.
From recent detections, has not yet reached Eutelsat 21B... seems between 21 to 21,4°E
That's how I have it. No beacon peaking on 21B yet.
Another update already, TLE #11 of 5 Jan 15:04 UTC, 20.9°E at that time, but still moving 1° per day.
The ITU database has SES records at 21.5°E, so maybe...
To almost 12 hours since the last detection, it seems we are not moved... I wait for confirmations tonight.....
Tracking from http://www.n2yo.com/?s=40364 has caught up with the posts in this thread now :)
ASTRA 2G
LOCAL TIME:
10:13:12
UTC:
10:13:12
LATITUDE:
0.01
LONGITUDE:
22.44
ALTITUDE [km]:
35862.48
ALTITUDE [mi]:
22283.91
SPEED [km/s]:
0.02
SPEED [mi/s]:
0.01
AZIMUTH:
149.5
SE
ELEVATION:
+26.5
RIGHT ASCENSION:
18h 54m 40s
DECLINATION:
-8° 21' 24''
Local Sidereal Time:
17h 6m 25s
The satellite is in day light
SATELLITE PERIOD:
1220m
Update (for what it's worth)
Using the Ku beacon, as there's no Ka beacon on or near 21B to compare with.
Not much change, still about 1° West of 21B. Azaal TV mux on that sat showing to the left of scan, but peak some way down of course.
14:52 06/01/2015
Pietclock
125cm
SE Germany 50°N/11°E
hmm, so 21.5°E might be the test position...
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Or the X-band location ;-)
skomedal
This and that
thule
Off topic
Find its a bit ironic that Astra 2G was launched on a russian rocket with a x band capabilities primary for aid worker communications, but can also be an aid to nato.
Regards
Retired Mod
www.timo.me.uk
Off topic
Regards
The same thought occurred to me, not to mention conspiracy theories that they tried to delay 2G enough to cause problems.
Pietclock
125cm
money does not smell...
