Technomate TM-5402 HD M2 VS TM-5502 HD CI+
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
Hmm just about to order to order an M3 version but the discount code WOS gave me does not work, waited all day for a reply :(
if only it could decode 4.2.2 also, oh well maybe some day !
@Phantom is trying to implement it via 3rd party sw atm but if its possible we will have to wait and see
remlap
Wales
What does that mean, does it mean the box could decode 4:2:2 with its processor or with the decoder chip?
digi247
NW
see sig
Its either one or the other or perhaps a Combination of the 2 combined, This will only work i assume on the new Mark 3 version of the 5402hd
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Technomate tell me they are working on 4.2.2 Could be a month or so for an update, rather exciting I think :)
remlap
Wales
Just at a time when H.264 4:2:2 is coming into use more and more ... sigh.
Costactc
Canada
So it seems as if the 5502 is basically identical to the 5302. However, the 5302 blind scan speed is brutal, is the 5502 the same?
digi247
NW
see sig
I should certainly hope so its the same receiver in a different style box one which accommodates an internal hard drive with the extra addon part from TM.
Hardware and software are identical
wod
yorkshire
Does the 5502 have a card and cam slot?
I've checked a few website including technomate and just want to double check.
I'm looking at buying this one over the tm5402 hd which I've read isn't as good the m3 model.
Laser
No more news on 4:2:2 does anyone know?
digi247
NW
see sig
Here is the official Tech Spec:
  • Fully MPEG-2, MPEG-4 & H.264 compliant
  • DVB-S & DVB-S2 complaint
  • Output resolution: Full HD 1080p, 1080i, 720p, 576p, 576i & 3D Ready*
  • 1x Smart Card Reader & 1x Common Interface (CI) Slot
  • HDMI Output
  • Dolby Digital Plus compliant via optical S/PDIF output
  • 15,000 TV & Radio channel memory
  • USB PVR Ready via a USB-powered external device: Rewind/Forward, Slow Motion Rewind/Forward, Timeshift (Pause Live TV) & Record Scrambled/Free-To-Air (FTA) channels, play Mp3 files & JPEG viewer
  • Record up to 2 channels (on the same transponder) and playback a file at the same time via USB
  • Fast Ssoftware download & Channel List upload/download via USB 2.0
  • Update software over the internet
  • Very fast & detailed hardware Blind Search (power scan)
  • 1x Scart Output with RGB and CVBS support
  • Ethernet Port
  • Super sensitive tuner for very weak signals and weak transponders
  • Less than 1 second channel change
  • PLL type RF-Modulator (Ch. 21- 69) and UHF tuning function
  • DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
  • DiSEqC Indicator
  • Enhanced 16 Favourite channel list groups and sort function
  • Auto Navigation system - select as many satellites as you want to search automatically
  • Extended EPG and programme reservation on EPG
  • Fast & easy-to-use menu system
  • Channel control by: Favourites, Lock, Skip, Move & Delete
  • Channel sort by: All, Alphabet, Transponder & CAS
  • Parental, Installation & Receiver password lock
  • Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Greek, Czech
  • Support for multiple audio language broadcasts
  • Automatic digital satellite signal detecting function
  • Manual transponder editing
  • Supports PAL/NTSC systems
  • Parental Control
  • Last channel auto-save and recall function
  • Various games
  • Multi-picture display
  • SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
  • 4:3 & 16:9 screen formats
  • Timer & multi-event timer functions
  • Automatic FEC and PID detection and manual entry of PID values
  • Pause capture
  • Loop through tuner and satellite
  • Real time clock
  • Teletext & Subtitle support by OSD and VBI
  • LNB short circuit protection onboard
  • Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
  • 1W Standby power consumption option
**not all 3D formats are compatible & requires a 3D TV
I assume the Card reader and Cam slot are behind the front flap as in the 5402 model, Just be advised that bot his and the 5302 being identical do not use the same channel list format as the more popular 5402, F15, CT4100 etc.. as in the .CNDF format, and the Channel editor is pitiful to say the least.
Using with a standard Diseqc motor and USALs wont pose a problem but using with an actuator or 1224 then any list you had previous with a .CNDF compatible model is useless with this one as you would have to let the 5502 assign new stored satellite positions
digi247
NW
see sig
TM Community aka Phantom posted this is not possible and the last we heard they where trying to attempt Multi-Stream option instead but dont hold your breath
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
i have the 5302, its great for blind scanning, although slow if you do the full range (about the same as tm 6800 which is what i compare it with), the tuner is sensitive and i use it mainly for blind scanning. the 6800 i still use for main tv watching. i have all sorts of problems getting the 5300 to reliably control the v box, and i have gone to the v box controlling the dish on its own. i have also found problems pre programing recordings i like the 5300 but it is a" animal" as i think william 1 described it.
Yes the TM5502HD is a bit of an animal but it is the best Blind Scan box available for us enthusiasts I use the TM6902HD as my main receiver for watching DTT/HD & HD Sat tv,
A couple of things you need to be aware of with the TM5302HD & TM5502HD
When editing the data base recheck the last transponder after you exit as the receiver invariable changes the polarization :eek:
For a quick start on feed satellites:-
Menu >> Advanced Search >> Press OK on any transponder >> Now Press the yellow button =Delete All >> Exit >> Exit >> Blind Search >> now set range & Blind Scan Step Scan >> Press the Red button to start,
I have found that with Feed Satellites this is a much faster method than going through the data base to delete dead transponders :)
