Costa Blanca, 2E/2F, seasonal signal fluctuation.
Menorca Man
Sky+ HD (2GB Amstrad DRX890) + Generic 1.65m x 1.5m offset with Opticum LQP-04H Quad LNB
Ciutadella de Menorca
Signal also well down here.....maybe -20-30% ......since Jan 1..... :-( .......
Seems the sidelobes are on the move again in my favour. Astra 2E/2F signals here in Menorca are starting to return to what they were last spring/summer. :)
mickwig
90cm Astra1 dish;
Signal a bit lower also since new year and the b****y snow doesn't help either.
We don't have that trouble here. Was 20ºC and sunny today.
Archive4
2E must be close to it´s first birthday now. Does anyone have recordings using the same set up to directly compare the signal one year on?
Huevos, I remember you started recordings on your 1.8m dish, is it a major work up to set that up again for a direct comparison?
joddle
Massanassa, Valencia, Spain
Noticed today that the shadow of the LNB is getting close to the centre of my PF dish around mid morning so I assume we must be due for some outages soon - Any0ne know when that is due here in Valencia? I like to check the at time to see if my dish has moved at all in all the recent winds!
Retired Mod
www.timo.me.uk
skomedal
This and that
thule
This is a good place to check exact times:
Thanks saved me looking for this site, use it twice a year:)
Regards
Pride Of Cucamonga
Valencia (city)
Here are the averages for all transponders (taken every 10 minutes between 18/02/2014 and 18/06/2014, 1.1m dish, 38.5N, 0.5W, including zero readouts where a transponder might have gone offline due to rain, etc).
10714     10729     10744     10758     10773     10788     10803     10817     10832     10847     10862     10876     10891     10906     10921     10964     10994     11023     11053     11067     11097     11126
8.71      8.60      8.82      8.82      8.50      8.78      8.52      8.96      8.48      8.84      7.56      9.06      8.61      9.27      8.53      8.95      8.96      9.15      9.27      8.99      9.15      9.22
Using this for realigning my dish today (thanks again, Huevos) following strong winds knocking it out . Planning on using 10832 (as 10862 encrypted) - is this a good choice? I understand 2E is still weaker than 2F so still better to aim for 28.35?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Normally use 10773 as the H frequencies here (Alicante) have proved more difficult to receive. Your suggestion of 10862 ( encrypted) is obviously ok if you are using the 'Quality' signal reading on your receiver to set up as opposed to a visual (picture on tv screen).
Just getting your strong winds here now together with a spot of rain.....reached over 24ºC yesterday sun all day so no complaints!
Best wishes, enjoy your weekend. :)
My 1.1m has gone offline on most transponders. Probably the wind has done the business on it. So got to set that up again. And with any luck, with this wind, the phone will start ringing again.
Pride Of Cucamonga
Valencia (city)
Went with your suggestion of 10773 - took bleeding forever - every time I had a strong signal I tightened the bolts and the signal would drop again. More winds to come so may be futile anyway and I'll have to do it again! Roll on decent IPTV (admit probably heresy in this forum!)
Archive4
I know what you mean! Set up a LH 1.1 last week to test signal round here (on the fringe) but have not been able to use it yet due to wind. Have decided to set up a "bent" Fam 1.37 as test dish, it will move less in the wind!
As for the phone.........mine is on message only for tonight! (wind speed in excess of 70 Kph) gusts higher!
My LH110 is using the old style wall bracket without the gussets.
Archive4
Mine is on the 50mm we use for the 1.4! Fam, but the design of the mount assembly is ****, (under engineered) so it acts like a jelly fish in this wind!
skomedal
This and that
thule
Archive4
There is already a dedicated IPTV section on this forum:-
https://www.satellites.co.uk/forums/iptv-internet-based-web-tv-streaming-support-forum.600/
Internet streaming is the way forward for fringe reception when all else fails, use it to stream uk psb channel when astra 2e does its daily wobble.
This site may also be of interest found it today on another forum:-
http://www.shadownet.ro/channels.php
Good luck
Regards
Iptv? What is that?
Get a bigger dish
skomedal
This and that
thule
Iptv? What is that?
The new tomorrow:-rofl2
I hope you'll take your Installer to task for this shortcoming.
