- Some SAT-related hardware.
- N-E from Riga
That is what I am afraid as well CH. 2 dishes, same horizontal dimension, same LNB located in focus and aiming to the proper spot.... those systems will give us same performance. In such competition is impossible to find out which dish has better metal mesh inside the plastic!
Only difference can bring us different results is- opening angle of the dish! And on my dishes #1 and #2 this angle is 79* and 89*. So, that mean that with same LNB we can get different performance of systems. But, if LNB's illumination angle is 84*, than in first case that will overiluminate dish #1 and in second case it will underiluminate dish #2. What is better- I do not know. Perhaps we should look for 2 different LNBs, one with 80* illuminating angle and another one with 90* illumination, then our systems will bring same performance again!
But, here we can continue small argument: Some are saying that CM120 is perfect antenna and producers designed it properly in such a way that LNB is pointed directly to the very center of the dish!
I am declaring that on the offset dish LNB should be pointed lower than center of dish and CM120 producers, perhaps made not perfect design.
I will be ready to apologize if I am wrong about aiming point of the LNB. But, somehow I am positive my statement is correct.
