Satellite card
ngj35uk
skybox f5 with single satellite lnb
sheffield
What would people recommend for under £100 in the uk any advise would be greatful
The Skystar Express HD2 will easily fit the bill pricewise. Around £50 - if you have a PCI-E slot in your PC.
Its specification comes close to the excellent TBS6925 card (or its latest equivalent), which would set you back maybe three times the price.
There's also a USB version of a similar card, which I am thinking of getting.
ngj35uk
sheffield
Thanks people will look at getting one
It says 5 in stock..
tempo
47.5N, 42.2E / Russia
A lot of SkyStar tuners are on ebay.de
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Archived-1
Persona non grata
uk
¿Do you have to ability to blindscan with the 5980 and do you find the tuner to be sensitive with low SR values?
Hi LP, yes you can use crazycats blind scan just same as the more expensive cards, the tuner is not very sensitive though to be honest but the skycard is the same comparing them to the X2 and skybox f3s
ngj35uk
sheffield
I bought the skystar usb 2 in the end what is the best software to use with it just having a play around with it now
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Depends what you want to achieve?
N
ngj36uk
i am after anything to tell me what transponder I am on also a good dvb viewer
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
I use the paid software "dvbviewer" this will allow you to tune and watch.
It also has an extra bit of software called TransEdit which you can use to do more technical stuff, tune individual transponders etc.
remlap
Wales
Has anyone compared sensitivity compared to the 6925, I am very interested in this card as an affordable backup.
Don't know about the 6925 but the Xpress is very close to sensitivity of the F15 receiver.
