Archived-1
Persona non grata
- uk
Sorry Rimants, I thought you was giving them away the other day.
Why not. But they are not perfect. If I am making new ones that means I am not satisfied with old. So, basically, one installed on the dish will stay, but the rest is waste. Anyway, I need to practice weldingI thought you was giving them away the other day.
Why not. But they are not perfect. If I am making new ones that means I am not satisfied with old. So, basically, one installed on the dish will stay, but the rest is waste. Anyway, I need to practice welding![]()
your only doing daily 120cm antennas laser pointing tests then ?
, if your only messing with thin stuff like that it might be worth investing in a sheet metal hand cutter no fumes
but don't lose a finger
I see your welding skills are improving a big deal .I've painted some LNB holders last night. And painted they look like made of....... you will not believe!..... not polished INOX!
So, there is my plan: Next Sunday (can not do it on Saturday, as I godrinkingfishing to the North sea) will take down Fibo 120 from my balcony and instead of it will erect CM 120.
I start to suspect that there are 2 different types of feedarms available for the same dish: one to be used with original feedhorn and other for universal LNB.
Yes, I've seen those before as well, but this is a different arrangement.seen the side on arm,s before but on larger dishes with buc ect. the 3 dishes i have are all the standard type. the feed/lnb in your picture are c-band not ku-band
For the standard 'Type 120' dish?From my googling and enquires there are three types of manufactured feed arms ?.
Anyones else have feed arms like this on their Channel Master dish, or has seen one before? Does anyone think that the fact that it is probably (according to the logo!) an "Andrews" dish make any difference (which would make it newer!). Thought that they were all the same?![]()
And we can get them made by ourselves out of.... you know what materialAnd we can get these arms...
