Crazy Scan for 18ghz
Yes, Crazyscan v88. Won't work with the TBS 6983 though, only cards like the TBS 6925/5925 and Skystar Xpress HD.
You could use the 6983 in Crazyscan using the Ku Band option. Only Ku frequencies shown though, and the spectrum will be reversed.
Trust
Nijmegen Netherlands
Hey Guys I'm planning to buy a satcard for my PC , should be used for Crazy scanning , ofcourse also KA .
What shall I buy ?
What shall I buy ?
If it's for Ka working, go for one with open-source drivers, such as mentioned in my reply earlier. As good as the TBS 6983 is, Crazyscan won't allow you to change the LO frequency of the Ka Inverto LNB option if you use the SL3 LNB.
OK for other Ka LNBs with recognized LO settings though.
Trust
I do have a Profcard 7301 somewhere , could that be of any use with Crazyscan ?
Yes, fully supported (stv090 demod)
http://sourceforge.net/p/crazyscan/wiki/Info/
Trust
Great Llew , thanks !
Archive-8
[SATTYPE]
1=0192
2= Astra 1KR/1L/1M/1N
3=0
4=9750
5=10600
6=11700
[DVB]
0=1
1=11432,H,3109,12,149,|-81 dBm, 5.3 dB
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
... can I trouble you as well please Chris
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cheers Chris ..
left it downloading ..
My bath is run ..
Time to jump in ..
later buddy
I had tried version 1.0.2.118 when it came out, but still couldn't get it to change the LO in KA Inverto option.
I'll try your version if I may Chris, could you send me a PM too please?
.... thank you Chris, your a gentleman.
